Steve williams
Or how about styrofoam coffee cups, or hockey pucks etc. They all do the same. Just a matter of whether you want to pay for something pretty that does exactly the same as the styrofoam cups
I use the same. Best part about the Dark Fields is that they are so easy to put away and re-place.
I've used them for years to keep the cables off the floor. No sonic benefits whatsoever
Right after I installed them . For me the only purpose they serve is to tidy up cable runs and to keep them off the floor
Only how they looked. No change to my ears but YMMV
Helium and electricity don't mix.:b
It was a humbling experience...
this whole subject falls into the catagory of things you do when you've done everything else possible. when your system is already tweaked. just 'in case' it might matter.
It was a humbling experience as i quickly learned in a simple swap out test done blinded. I failed miserably. As I said YMMV but this one test on a Saturday afternoon quickly changed whatever positives I said previously. In spite of this I still use them. I noticed in the Shunyata review done on Soundstage the differences were said to be minimal. Well, isn't this waffling by someone who had high expectation bias
But an honest and important one at that.
At the very least; cable lifters are non-quantum/charlatan type tweaks that don't pretend to sell impossibility. In this case, any false pretense can easily be verified without having to spend silly money. And, they may even work to some degree depending on the floor & cable type/interaction.
tb1
