I am buying some IAP-325-US and I will look those over. Those are 4x4.. https://www.securewirelessworks.com/datasheets/Access-Points/DS_AP320Series.pdf
I need to find a access point to recommend for the Switch X. Right now everyone is using access points they have or Bill and I suggested the Eero. These all have produced great results, but, I am now thinking a Aruba is the best path. These are a issue tho as a Aruba is designed to ceiling mount, so how to get it to sit on a shelf has to be worked out. Also a linear needs to be worked out. The ethernet and power both poke straight out the back of the Aruba. So. I gotta play with this to make it shelf ready. I am thinking of supplying them ready to go with the right config and a linear. They are cheap from ebay and I think I can find a cheap linear, no mods needed, just config and some way to set them on a shelf.. So I am hoping to keep cost way down.
I have a really long term client I am working to supply a full system with a access point , SFP, and Switch X all in one box ready to go and ready to hook to a Taiko via Direct Attach Cable.
