David Karmeli’s Bionor/Lamm/AS-2000 Audio System
Hi Michael,
Wired in series, the first bass acts as a pre-impedance. easier to drive for the amp so you increase overall quality (qts). This means that the bass plays with more sound pressure at its resonance frequency(fs). This means that the decay occurs later at a lower frequency. Unfortunately, as always, there is a disadvantage: the impulse speed becomes slower. Only you can decide whether you still like it.
Cheers
Stephan
The old Infinity IRS Beta and IRS V had an electronic crossover that had a Q adjustment, which could make the bass dry as sawdust or dripping wet and bloomy. Was fun to dial in the bass transients and decay with this adjustment…however a Qts between 0.6 and 0.7 was where I settled and where most good box designs end up.
Hi Michael,
Cheers
Stephan
Impulse is not slower, it's just less controlled. Q is a measure of damping. So when you hit it with signal it's a measure of how quickly it settles electrically or mechanically (electrically it can be a measure of how much an amplifier's feedback reigns it in even at impulse to retain the frequency). There's more to QES/QMS with frequency, but that is the basics. Yes if you have high Q you can play past resonant frequency (lower), as it does not naturally dampen that signal to nothing. QMS essentially only works at and below resonant frequency (mechanical damping).
Qts 0.5- 0.7 is good for bassreflex/sealed
Qts 0.2-0.3 is good for horn
Qts 0.9- 1.2 is good for open baffle you lost too much sound presure without housing in bass.
I made a cautious estimate of the frequency curve, which would be difficult without on-site measurement. 2x Bass bionor parallel (green) (yellow) series wired woofer 6-8hz lower.20231128_165333.jpg
Reactions: FLHX84
Thanks,I need to learn English better, we're basically on the same wavelength.;)
Reactions: Folsom and FLHX84
The Klang 405's are higher than typical for a horn but as mid horns it doesn't seem to cause any issues. There isn't much for loading, it's mostly focus.
The Horndriver KL L302 driver produces a lot of sound pressure from 500 Hz to 15 kHz. They actually wanted to mount the two KL 405s in an infinitely large baffle (open baffle). There you will notice that the sound pressure was incorrect and it was not possible to transmit it at the right time.
Remember that the speaker was built for the cinema, not for home. So they killed two birds with one stone. Higher sensitivity below 500 Hz over 100 dB/1 watt and time adjustment with the Horn for bass driver. These are speculations on my part. To be sure, you would have to measure it.
Reactions: FLHX84
Reactions: Carlos269
Michael, that is truly a fabulous looking office and system. If you’re taking requests for music for a video, I would love to hear Peggy Lee’s “Fever“, Or anything by Ella Fitzgerald, and a string quartet.
Hi Peter,
here is Peggy Lee… String quartet will follow the next days, any special wish?…
Best regards
Michael
Reactions: DasguteOhr
Hi Peter,
Best regards
Michael
Thank you very much Michael. I appreciate you making the recording, and so quickly. Please tell me about the digital player off of your phone?
For a string quartet, how about Beethoven Middle Quartets, or anything really. I just want to hear some strings. Could you also share a recording of anything you want on that turntable?
Hi Peter,
Apple Music file played through iPhone’s digital out into a Topping DAC and then into th CAT preamp and the two V69…
Will try to make the other requested videos in the next few days…
Michael
Reactions: PeterA
Hi Carlos,
here are the links…
Best regards
Michael
Michael, thank you for taking the time and the effort in making these videos. I really appreciate it. The system has that vintage sound of the era and it’s nice to see that you are enjoying these historically significant components many decades later. Again, thank you! I appreciate you posting these. No further requests from my side.
Here is another video of Peggy Lee's Fever on ddk's Bionor system. These big paper woofers really do a great job of presenting bass.
I got the album but cannot say I like it. Elvis did a version that is better. In fact there are many version I like more. I think the Peggy Lee album is a dud imo.
It can sound just fine but the music is just meh.
Hi Folsom, People have different tastes. I like this recording and took the LP to Utah and made the recording when visiting David. The purpose of the video is just to show another example of a Bionor playing the same recording that FLHX84 made a video of on his Bionor system.
Some lurking trolls haunted by the specter of ddk will find my post and have trouble containing themselves.
I am just saying you can listen to it online but if you go seek the album like I did, don't expect much from it imo.
There are so many good albums used in videos that I like, that are worth seeking.
Better cover your ankles Peter ! :eek:
@FLHX84
Congratulations on a fantastic sounding system; I too have a vintage horn based system. How did you decide to use the Telefunkin amps in your set up?
The ghost of ddk lurks amongst us.
Reactions: tima and Lagonda
Indeed. It is a thread about his system originated by a visitor. It is nice that another Bionor system is also being discussed. There are some interesting similarities and differences between the videos. There aren’t many places to hear these speakers and there are many people who own them.
Reactions: tima
I miss ddk's contributions. I guess Carlos has been voted off the island for a while, too. Even with their entanglements, they entertained me.
