Fantastic news, iamtimbabb! Very exciting. I cannot comment on connecting to speakers...as long as you are following the strict guidelines about that, I have heard that is a universally great thing to do...not heard of anyone not liking it.
As for binding posts, I DID experiment with the 2nd binding posts:
1. Removing the stock standard wood binding post and replacing with Everest or Peak 4
- Interestingly, of all the connections, I preferred Peak 4 over Everest in EVERY CASE
- HOWEVER, I preferred the original wooden binding post over the Peak 4 in EVERY CASE, EXCEPT ONE: Subwoofer RCA Signal Ground
- WHY - mainly because the Peak 4 continues to hone the signal in a fantastic way, and as a primary binding post just made great strides...but attached to the 2nd, it seemed to 'ever-so-slightly' lighten the upper bass weight even as it created more dimensionality
- The net result was further insight/detail but the instrument 'corporeal body' started to lighten where it did not have that startling in-the-room realism
- So we basically stopped it, called it a day and have sat back to enjoy ever since
2. Connecting two different modules (ie, eartha Olympus from the 'primary' binding post of 1 Tungsten module to the 'primary' binding post of a 2nd Tungsten module.
- Worked well...more of everything
- This was for the mono amps
- What we did was take a standalone Olympus Infinity Tungsten - which as you know is ONE modules with TWO binding posts - and connect it to 2 modules of the Pluton (where the 2 Pluton modules were driving 1 Monoblock amp each)
- Of course, this was not really your question (ie, what to do with the unconnected 2nd binding post)...but given that you are experimenting, thought I would share this with you
