Entreq Tellus grounding
Yes, from what I gather, superseded now by the Triton @ £1000, £500 cheaper than Eartha Olympus in the review ?
Interesting...from their website, they seem to suggest Triton is in the middle of their range? Eartha Olympus is listed on their website as 'the best Eartha cable we've ever made' while Triton is listed as an 'Eartha cable to fill the gap between Apollo and Olympus.'
I ordered a Russ Andrews Plug in router. I intend to try it many ways including into my Entreq Silver Tellus.
ozzy
How could the plug-in version work "into" your Silver Tellus? It is designed to take chassis or signal ground wires from components and "drain" them into the house ground via the wall socket (i.e., instead of draining them into a "box of dirt"). I assume you could substitute the Tellus for the copper rod with the standard Router.
I think the Entreq Olympus Infinity Tungsten is around $4000? in the US and it definitely is £4000 in the UK. So despite currency differences as you point out, import tax, etc, etc. seem to have created this disparity in pricing.
The Olympus Infinity T is listed for around US$4900 since day one in North America. Don't know where that US$4000 is coming from.
April 2022 Review of Olympus Infinity Tungsten & Eartha groundcable on Enjoythemusic.com.
It's not clear from the review how long he had it connected in his system before doing the review? Seems like he had the Entreq since December and only now doing a review?
I'd gladly pay that for mine. I had to pay the equivalent of $7000 US for mine. (package price with two Apollo cables)
I will say...in terms of the unique kind of upgrade that the Entreq brings as well as the sheer quality of that upgrade...I am also very happy with what Entreq has done. Extremely good results.
cellcbern,
I'm going to plug one of bananas from the Russ Andrews unit to one of the Entreq grounds (banana), I guess the worse would-be hum or no improvement. If that does not work, then I will try chassis ground.
Experiment...
ozzy
cellcbern,
Experiment...
ozzy
The Russ Andrews plug-in unit only has inputs except for the wall plug through which it dumps the noise into the house ground. I thought that the Entreq unit was an end point only. I suspect that nothing will result from plugging the input of the Russ Andrews unit into the Entreq, but I could be wrong. If you had the standard Russ Andrews RF Router (or similar Puritan Groundmaster) you could use the Entreq instead of the copper rod as the end point.
Note that you will be in a position to do a head to head comparison between chassis and (separately) signal grounding via the Entreq vs. the Russ Andrews unit, thereby providing a great service for all of the posters who have not yet ventured into grounding and are wondering how a much cheaper option like the Russ Andrews or Puritan performs vs. the much more expensive Entreg. Note that in my experiments with the very similar (to the Russ Andrews plug-in unit) Puritan Groundmaster City I found that signal grounding from unused rca inlets on my integrated amp and sacd payer made a much bigger improvement than chassis grounding both those components and my power conditioner, and sacd player's separate power supply. I used the Russ Andrews Technical Ground Weave cables (which are Kimber wire) with rca plug on one end and banana/spade on the other for these connections.
FYI - my experiences with this are posted at the Audio Tweaks forum in the "Grounding Boxes" thread, starting with post #69 - 12/30/21.
Confirmed with the North America distributor, the price of the Olympus Infinity T is US$4900.
Hi all my audioholic mates,
I thought of telling you my Sunday morning audio testing story.
I tried draining my signal cables as well, as they were luckily born with shield output.
I attached them through two ENTREQ Eartha Apollo ’s to two Olympus Ten Infinity Tungsten’s.
Results were… wow, more headroom, lower noise floor and harshness, more air and clean soundstage, more speed and overall dynamics. Sound came just a bit more forward by its own but connecting the CLEANUS brought it back again, so I had much more space between the instruments, with the voice well ahead and the rest spaced in depth and very holographic.
A strange phenomenon though caught me by surprise. At a certain point, going from four to six ground boxes, I achieved LESS definition
Adding the two Olympus Ten Tungsten ’s on signal cables AND one Olympus Infinity Tungsten to the CLEANUS, funny was that the sound became a bit blurred and apparently LESS defined, BUT more delicate, deep and full of ambience info. Well, now such things would indicate to me a SURE improvement!
In fact it took me a while to understand what was going on and finally it was clear that the sound had LOST so much noise that all LOW LEVEL info (harmonics which were previously buried and canceled by noise) started now to be released by playback, resulting in an apparent step back in sound quality but which was a resuscitation instead!
In fact the soundstage was well behind the speakers, with all ambience of theatre or hall MORE present and sensible almost like a reverb was added to the sound! PRECIOUS information which was before cancelled by noise and now was slightly embedding the musical message compared to before but because it was there, captured by the recording.
So that was an improvement and not a loss as it seemed initially. Yes, there was a bit less definition because there were much more low level harmonics. In my mastering studio I have a special device, Dolby Spectral EQ, which works basically on those info.
You can set the threshold of level below which you wish to intervene, say 20dB, so if you raise high’s like that you will not influence the fundamentals but only increase the air and the natural ambience information.
Amazing machine, btw.
Probably if I had never used it I would be deceived by yesterday’s tests.
Testing is a difficult task, since you really must interpret all steps, thereby I am sharing this story to help others.
So it only took a couple of PEAK4 ’s to get back all definition and speed back but this time together with an incredible naturalness. Now the sound was a bit MORE defined than before and much deeper and less harsh.
I am going to try a total of ten screws, choosing among EVEREST ’s and PEAK4 ’s, to finalize what promises to be an amazing final result thanks to ENTREQ.
Stay tuned, guys!
Fabio
What a great post! Enjoy and look forward to reading more.
Reactions: gkg2k
I pulled the trigger on the Pluton with Olympus cables. I will have a full set of Peak 4 and Everest knobs, as well as a set of Apollo and some Silver cables for experimentation. This will be in addition to the OI T and the OT T that I already have. The OT T will be used from DAC, and the Pluton for Amp Signal ground and Negative Speaker terminal grounding. Once the Pluton arrives the OI T will be on standby until I decide best use for it.
I don't expect to receive everything before the end of the month, but that is the timeframe given to me. All my previous orders have been messed up, and I have pleaded with my dealer to make sure this order is correct the first time, so I will just have to cross my fingers.
On a side note, I was going to go with the Triton, but since it not yet available to me, and the positive threads I have read from gkg2k & LL21 convinced me to just go with the Olympus. I will have the Apollo as backup in case the Olympus is too much.
Reactions: gkg2k
Congrats! Look forward to that...note, 5.5 days on the initial audition is what it took to 'really start cooking'...and we ended up taking 12.5 days with the actual system we put in because the cable lengths were much longer.
Looks like Russ Andrews unit is caught up in customs. Been there for a week! I contacted the US Post Office who said there is nothing that can be done. Is there problems in getting electronics from England into the USA?
ozzy
ozzy
I've had three orders from Russ Andrews arrive within 10 days after dispatch over the last six months, but my last order has not materialized 6 weeks after shipment. Russ Andrews is shipping a replacement order via a different shipping method/carrier. Not sure what the problem is. Let Peter Bevir know if you haven't already.
