Hello Soundminded
From personal experience I have to disagree. I was at MSG for a concert a couple of weeks ago and was quite surprised just how audible the echo can be depending on where you sit. I was sitting in line with the stage and you could clearly hear the reflection from the rear coming back at the stage. It was very easy to hear. There was obviously quite a bit of energy reflected off the back walls.
I agree you shouldn't be able to locate the rears, they should just be a difuse field.
Rob
---- Here's the thing Rob; in a Concert Hall if you sit near the back or side walls you'll hear reverbs that are quite stong and it will affect the entire realistic soundstage, the full performance and experience. It'll 'destroy' the good things.
Remember too, near the rear of the hall you are usually sitting behind the balcony just above you, so you have a ceiling there that is much lower than sitting in front (main hall's ceiling).
The echoes (reverbs) are much much stronger, and they totally ruin the true direct essence of that live performance. ...If your goal is to have the best of the best of course.
It is primordial that you choose a good seat carefully. ..That means generally at center alleys between
G &
J. But some people like
K, L, &
M too, depending on the particular venue. ...
E &
F could also be fine, if the live concert is from a smaller ensemble, like chamber music; but in that case a much smaller room is preferable. ...And same for Jazz music with three to six musicians.
Furthermore, in that hall we are sitting below the actual stage where the musicians/singers are performing, or above it at the main rear balcony or side balconies.
So it is tough to grasp an actual and accurate live performance.
...You go for what is the most 'pleasant' and 'balanced' sound at the most positions possible, and you follow some basic guidelines.
I worked in a hall theater when I was young as an engineer assistant for sound & light, and I checked the sound projections from EVERYWHERE, even behind and at the sides of the main stage.
...Two totally different spaces (live hall and our room) and two totally different mediums (live and recorded music).
And you need more than 'magic' to get everything just right.
For me, both Stereo and Multichannel music have their Pros & Cons.
One can be as effective as the other if properly set up and with the right material (music mediums).
And most importantly, a properly acoustically treated room for one or the other, but not both, I truly believe.
