Well Bob Carver demonstrated his amp of a few hundred dollars could sound like a $5k amp. That exercise had effectively zero impact on the business. Comments here should show Blizzard a great product doing everything he claims will have the same results.
If only they had a free choice. If Brtney Spears is recorded only in digital. How do they get free choice?.How is pointing out the obvious trolling? Would you ever expect the CEO from Mercedes to go on a BMW thread and announce the latest BMW is superior? Obviously not.
And about vinyl, let me know when the production numbers surpass digital in popularity. Both downloads and streaming. If this time comes, I will take a more serious look.
Anyways, I think there's room in this industry for different ideas. Let's let the end users decide what's better for their needs and desires[Emphasis supplieed]. So no hard feelings.
Hi Tim,
How close is the emulation of the small, low gain, low watt amp to actually having said a pin the chain?
To achieve the dynamic modelling with sufficient fidelity, you would surely need a very complex multi-parameter model for all the speakers that the amp would be used with, which is clearly not commercially viable. The process involves recording the analogue outputs of these amplifiers.
This is an excellent example of trolling but rather than report it, there is something I have to respond to, so while risking breaking the forum rules by copying a trolling post, here goes:
We've been studying the class D phenom since 2002. It appears that we have something to bring to the table too. So you might consider the fact that to design a really good tube amp takes the same skills to design a really good class D amp; they are both analog technologies and both have been around a while- class D being first created about 1959 and FWIW its perfectly possible to built a tube embodiment.
Your opinions are uninformed.
An example is that the LP is not a fad. The period of least production was 1992-1993. That was, just for the record (if you will pardon the expression) 23, almost 24 years ago. Fad?? I'm sorry to have to put it this way but its blatantly obvious that you've got no clue in this regard!
In this post it seems that Blizz is OK with DSP sounding more 'analog'. I hear things like this all the time- digital sounding more like analog, transistors sounding more like tubes.... sheesh, the irony! And now we have to rely on our ears instead of bit of paper with the specs on it? The twists, the contradictions...! IME, when someone is willing to contradict themselves, its no longer about the topic. Its about something else unrelated.
Folks, its been fun, but this thread has outlived its usefulness. Sorry to abandon y'all, but until some of the obvious trolling has been dealt with I'm out.
Ralph, the BEST thing Blizz ever did on this thread was involve you. And then when he didn't get the response he was expecting (chutzpah off the scale!), basically ignore you. If he thought you were going to not contribute further, he obviously misled himself.
Now if he really believes what he says, why ask you in the first place?
Blizz, I just caught up w/my favourite "how far can you get OT" topic EVER. Just wanted to highlight possibly the most relevant post.
So, thanx again for getting Ralph involved.
He's showing more intelligence than the rest of us in bailing out when he did.
Hi Bill,
Though I know you asked Tim, I hope it's okay to put my two cents in here.
To your first question: Most of my experience is with the Kemper, so take that for whatever it's worth. I think clean sounds in particular can be really impressive - like "whoa, I can't believe that's not my amp" impressive. Heavily modulated/distorted sounds sometimes fare less well, depending on the complexity of the sound.
To your second question: An important distinction may be that with a profiling amp (again, I’m thinking the Kemper, which in my experience is by far the most proficient at "profiling" an existing setup - rather than "modelling" or mimicking pre-existing setups) is doing two things:
1. Capturing the amp/cab (and effects) at one specific setting (which does allow for compensation of pick attack and sag), but only that specific setting (however the amp's gain, EQ, master volume, etc is set at that particular time), and not the entire behaviour of that amp over a range of settings. If say, one takes a Matchless DC30 and profiles it with the Volume at 9-o’clock, one can’t then just crank the volume to 1-o’clock on the Kemper and have it sound the same as it would had the volume been cranked on the DC30. To get that sound one would need to crank the volume on the amp and then profile that specific sound.
2. Capturing one's choice of microphone. The Kemper is not profiling the amp/cab. It’s profiling the amp/cab as captured by whatever microphone is chosen and where it was placed it on the cab.
That is: the Kemper is not capturing the amp at all settings, in the room, as perceived by the player's ears - it's capturing the amp at one very specific setting, in the room, as captured by the choice of microphone and its placement relative to the cab.
As many have already alluded to, a valve amp used for hi-fi playback is going to respond very differently depending on the load it’s being asked to drive, the volume its asked to play at, and the musical signal it’s sent. Not only that, we don’t, of course, use an intermediary mechanism in between the load the amp is asked to drive and our ears - we perceive the sound directly from whatever load is connected to the amp. That is: there’s no mic involved.
The reason I think the Kemper has been so successful is because it’s not trying to emulate the entire behaviour of the amp/cab in question across all possible settings - just one. What’s more, it’s implicitly acknowledging it’s capturing not only the amp and cab, but the choice of mic and how it's miked it as part of the sound. Those two things alone will alter the results massively, and cannot be ignored as to their significance.
There's no hope for someone who thinks 90's video technology is better than today. At least with video, it's much easier to tell the better technology. Anyone with a good set of eyes can tell right away.
well, this personally quite embarrassing, because I had free choice ...
Let me agree with what Tom said and add that we like to enjoy and have great time this time of year. Please don't make work for us. Just discuss the topics, whatever they might be, rather than each other. You all bring value to the forum with respect to the topics, please stay with that. We are just getting too many complaints for a thread that should be interesting topic to discuss.Hello WBF members and good afternoon to you. Please allow me to remind you that personal comments are against the TOS of this forum. If you choose to state something directed at a person, think twice before posting as you may not like the end result of what happens to your post(s) or your membership status.
Keep all posts on topic and discuss the technical merit of the subject.
Now that this has been addressed, please be advised that any further personal commentary or off topic posts will be deleted and administrative action will be taken if warranted by the management team. Thank you.
Tom
I agree. I think this topic's been exhausted anyways. High end audio today is more about beliefs than the music and sound anyways.
My hope for the next generation of high end audio, is that we pay more attention to the music and the sound, than the form factor. I believe the only way high end audio has a hope in surviving the next generation, is by making the process of experiencing cutting edge sound as painless as possible. This includes mobile app GUI's and compact, highly reliable form factor hardware.
This will allow us to truly focus on the music, rather than the cumbersome process. But again, this is my belief, nobody must agree.
I agree with you on this.
I think your hoped for experience will not come to pass. High end divorced itself from high fidelity long ago. I think it will remain as a niche market of odd ideas, marketing of a difference (mostly when that difference departs from fidelity and reality), and expensive status driven products marketed to the magic, and mystery of imagining what is possible.
Hi Bill,
