You just called me out for having a different opinion.Everything is in context and no one should be calling out people who have a different opinion.
I own a 3.20. It has two 20 amp inputs, two completely separate circuits. Each has 4 outlets. You might be talking about maximum current draw for your Amp and Sub, but hopefully they don't both get there at the same time. If the only items going into each 3.20 are a 16 amp sub and a 10 amp amplifier you will have no problem with a 3.20. Sub in one circuit, amp in the other. You could probably add a few lower powered devices as well, favoring the 10 amp side. Does this make sense to you?Hi all, I read this thread and I know my question might be redundant but does anyone here know if the powerzone 3.20 is split in two as far as draw allowance? And how strict is it .
I want to get two pZ 3.20 for each side of my room; I have block audio mono blocks draw 10amp in class A ; then gryphon trident 2 active speaker for woofer , class an but max draw 16amp! And magico s sub max draw 16amp?! So in eight outlets one one side mono block and the other side speaker and sub , which totals 10a on one side and potentially 32a on other which would exceed 20a , thoughts?
Yes thank you … yes so one situation scenario would be on paper at risk of going over 20amp, I have three things I need to plug in , my 10amp draw mono block, my 16amp active speaker and also my 16amp subwoofer . But you’re right likelifhood at getting peak draw fromI own a 3.20. It has two 20 amp inputs, two completely separate circuits. Each has 4 outlets. You might be talking about maximum current draw for your Amp and Sub, but hopefully they don't both get there at the same time. If the only items going into each 3.20 are a 16 amp sub and a 10 amp amplifier you will have no problem with a 3.20. Sub in one circuit, amp in the other. You could probably add a few lower powered devices as well, favoring the 10 amp side. Does this make sense to you?
aangen: yes! It does! It’s just short of 2 weeks and I have to leave the PZ’s for a month. I’m working with a stock power cable to the 3.0 and a Cardas Clear Beyond XL to the 2.0. Both will become Vanta when I get back to the system. Vanta in place from the PZ’s to amp and pre amp.It keeps improving week after week. For at least a month. Welcome to the club!!!!
Not one you’d actually want to use…Does Powerzone come with any power cable?
That “one” isn’t me right…I was involved in setting up a group buy for 8 people to buy Powerzones. All except one have learned that the better the power cable from the wall to the PZ, the better the PZ performs.
Hi Luca: Looking forward to discovering what you already know in those 2 more weeks! The first 2 weeks brought plenty of changes, just as you described.Thanks for sharing, and you have 2 weeks ahead to get even further improvements!
I agree with Al, I'm using STEALTH Dream 20-20 and don't feel the need to try anything else.Just saw an YT video from Rune on PZ. He kept emphasizing PZ is not a power conditioner or filter. Very interesting. What are the suggestions of power cord from PZ to wall?
Well, he has to say that because it isn't.Just saw an YT video from Rune on PZ. He kept emphasizing PZ is not a power conditioner or filter. Very interesting.
