FWIW I just spoke to Joe Lavrencik from CMS re his thoughts about placing a Herzan on top of a CMS shelf. Here is what he said .......
" An active system atop a CMS filter would be highly redundant. Also it could actually degrade the functionality by interfering with the energy transfer."
Guys, this hobby is crazy enough w'out going to CRAZY levels
The Herzan active is good enough for an electron scanning microscope, yes? And so, good enough for our needs, esp tts, yes? If it's good enough, and in effect more than good enough, then surely mixing the two is just being greedy
Just install the Herzan, and be done
Or the rack, and be done
Just, be done
You don't see any lab owners feeling the need to piggy back/hybridise/combine techs
Or go beyond Herzan
Hi Spirit,
...The most common issue we have found when pairing high end audio equipment and active systems is the horizontal and vertical rigidity of support stands not being adequate. The primary way to minimize the effectiveness of an active system is to place it on an unstable support structure, so we advise either placing the system on the floor (which is not always practical), or looking into a support stand that has strong horizontal support points and is made of a rigid material (steel works well in most cases)....
- Reid, Herzan
Just, be done
Or go beyond Herzan
This is exactly what 'active' isolation stands are designed to combat and I suspect (contrary to other advice)....that the Herzan will solve this problem...
The only problem is arranging an audition.
With Herzan, they offer a 30 day satisfaction guarantee so if it doesn't work out for you...you are only up for transportation costs.
I'm in Australia and that's the same risk I undertook :b
Peter, any confusion not intended
Ok, to explain
Some years back the Herzan active isoln bug strikes w Mike L and Christian R reporting stellar results...but at a cost
At the time, I secure a home trial of equivalent active Accurion/Halcyonics i4, and hear overall impvt, but not quite as stellar as I was expecting (something to come back to as I was in the middle of a major tube amps upgrade, and I couldn't afford the NATs as well as the £7k Accurion)
A few years back I get news of Purite Keith who had just installed the passive air rolling diaphragm Spiers Robertson AMB under his GP Monaco 1.5/Triplanar/Dynavector, and according to him it enabled him for the first time to properly benefit from having the tt
Put it this way, he has the most brutal nodes in his room at 37Hz, and 70Hz, and previously they caused the most terrible smearing of information from those grooves and mistracking
W the passive Speirs under the GP the whole analog side of things just clarified and solidified that even the most torturous nodes on my bass heavy lps that I demoed there did not disrupt things
A truly slam dunk positive outcome and a massive advert for the passive Speirs
On making contact w the chief designer, assuming the 3x pricier active Speirs would take this advantage on, I was surprised to hear from him that wasn't the case, and the passive I heard was the unit to order
In the meantime I continued upgrading the rest of my system and got to a synergy 18 months ago that for the first time struck me as a stepping off point from more and more expensive component spending
And then I put my system away for a year, moved, threw $90k in creating my dedicated space, w full acoustics and leading edge power install, and as you know I just love what I've achieved, now w no need to change gear at all
But w some reservations on analog presentation (although impvg on a daily basis), my thoughts return to the subject of isoln
So, I'm at a point where I'm reinvestigating the last major spend on my rig, tt isoln, because I was so impressed w how the Speirs passive dealt w such a brutal room at Keith's, at such a modest outlay
This is where I had been planning my spend
