Transmission line rear horn loaded speakers can do bass. The issue is that feedback can diminish it greatly because of how they work. That’s a problem for more symmetrical, consistent, bass production like found in more modern music. Try something that doesn’t really have much for feedback, or a current source amp on a single driver and you’ll be able to rock out to EDM just fine.
Spatial cues are higher frequencies. Bass is just vibrations till it has accompanied frequencies defining it.
Yes, they can do bass for sure. As I have written it would also be clean and can be powerful. It will not however be time aligned with the rest of the system. This is physically impossible. It will therefore create effects that can be more or less audible depending on the recording. That is why it may be disjointed with more modern music, not because of levels of bass are higher or similar.
Can you share which ones that would be for you?
I can live with Vandersteen model 7's. Altough the speakers are very different than mine, our approach to crossovers is very similar.
