If you could..what would you......??
DaveyF
Administrator
Aug 1, 2010
6,135
122
63
La Jolla, Calif USA
#1
If you could replace your current speakers with another make/model...and budget was no issue; what would your #1 choice be?
However, let’s make this a little more interesting...to add to the question, let’s assume that your current room and your current electronics have to be taken into consideration. So, if you have a small room, then automatically nominating a speaker like the Wilson Wamms would not work. If you have a liking for a very inefficient speaker and you already own and like a flea powered amp, then nominating Apogee Scintilla’s would not work, etc.,
Ok, let’s hear em...:cool:
ddk
3,640
139
63
Utah
#2
Not exactly true there are ways to get a big speaker to work properly in a tight space, there are other properties of the room that come into play that can destroy the sound even if the space is large enough.
david
Folsom
2,954
106
63
Eastern WA
#3
I never get where the concept of large speaker means large room. Generally larger speakers have larger drivers, which makes them more adept to a smallef space since they have higher directinality. Basically the opposite is true of what people want to think.
So long as the physical space allows, it isnt a bad idea. In the case of dipoles and open baffles min space is required.
DaveyF
Administrator
Aug 1, 2010
6,135
122
63
La Jolla, Calif USA
#4
Jeez, you guys are right...why didn’t I think of this all along; I should have bought Gary’s Genesis Dragons and made them work in my 10x9 room....you think:rolleyes::D:p
K, shall we get back to my OP...
ddk
3,640
139
63
Utah
#5
If you have the ceiling height!
david
Jul 25, 2012
2,556
2
38
NY
#6
You might have room for a chair! :D
Uk Paul
356
24
18
UK
#8
I would feel physically uncomfortable sitting in front of a large speaker system as mentioned in a small 10 x 9 space, so much so that they simply would spoil some of the enjoyment of the music no matter how well they can perform in the right size space. A speaker should (IMO!!) fit visually and sonically.
Anyway, to Re-rail Davey's thread, in my room, two models spring to mind: Martin Logan Neolith and B&W Nautilus. I have a good idea of what the Neolith would do and am very open to the experience, but the Nautilus is a thought based decision as I have not heard them before, so I base this choice on my understanding of speaker design and construction..
259
83
#9
I have tried the big Soundlab A1's in a 9´x 15' room and they sounded great.
259
83
#10
I would feel physically uncomfortable sitting in front of a large speaker system as mentioned in a small 10 x 9 space, so much so that they simply would spoil some of the enjoyment of the music no matter how well they can perform in the right size space. A speaker should (IMO!!) fit visually and sonically. (...)
I share your view - particularly because such system would usually have a minimal sweet spot , small variations in position causing abrupt and uncomfortable changes in sound. Each of us has its own way of listening to a system, and we often forget about it when commenting equipment.
May 12, 2017
163
5
18
Texas
#13
I would replace my Aviors with the Lyra and just learn to live with the bigger speakers:cool:
DaveyF
Administrator
Aug 1, 2010
6,135
122
63
La Jolla, Calif USA
#14
+1.
Thank you Paul.
Maybe I should start a new thread...that one would be titled----what huge speaker system have you crammed into your room and kludged up the rest of the system to make it sound acceptable?
Meanwhile, I would like to get back to my OP.
BTW, I have heard the original B&W Nautilus, it is a heck of a great speaker! In some ways, it is very reminiscent of the current top-of-the-line Vivids, as it should be- since the designer is one and the same. Up until a few years back, I would say it was the best speaker I had heard. Would have been my choice in a mid size plus room if price be no object.
DaveyF
Administrator
Aug 1, 2010
6,135
122
63
La Jolla, Calif USA
#16
One of the things that impressed me about the Lyra's, is that they are not that large a speaker...and yet can apparently compete with some of the much larger systems out there. Nonetheless, if they were NOT a good match for your room...and the Avior's were better, would this in fact be a wise move???
May 12, 2017
163
5
18
Texas
#18
Good question...I believe the Lyra was designed to sound big with a more accommodating footprint but I never worried about speaker and room size. I have kept the Avior because it works in my room and probably won't change speakers until I change rooms. I imagine the Lyra would work but not the Arrakis unless I want them to go through the ceiling.:D
#19
I would like to try the large Focals, but I think they will not be efficient enough to replace my Vapor Nimbus. I use 30W SET amps.
Steve N.
Empirical Audio
GMKF
351
28
28
Munich
#20
I'd like some Magico S7's. Please :D
With Wavac SH-833 SET amps....
