Bruce
Are you running the speakers full range as we do
No, rolled off at 90
I play mine full range and use the subs to supplement up to 35 Hz
Full range with Velodyne DD18+ at 36db rolloff above 40hz.
Did the woofers menace to go on strike?![]()
why so low?
Because anything more would overload and sound terrible. This is where the system sounds best. I run the speakers full range and cross out everything above 35 Hz on the subs. They used to be 43 Hz but since I added the MB loom of cable the sub had to be readjusted
Thats interesting. I would think with the subs crossed over higher you could control the bass output better and minimise the bass overloading your room
just saw this....and haven't even had time to read Marty's post in full. got to get to work.
congrats Marty and I'm expecting you to wring all the juice from that turnip and rock those Wilson's.
Congratulations Marty - a great choice. And yes, setting big Wilson's needs a lot of effort and time, but the results are rewarding. IMHO the bipolar opinions on Wilson speakers is mainly due to the fact that some people listen to them in improper conditions, as they are not drop and play speakers. Have you considered using the Gotham's DARO to equalize the subs, the S2 full range and the CR1 just to blend the subs to the main speakers?
First congrats on the great speakers...a few questions if you don't mind
What is you speaker spread distance and how far do your ears set back from the speakers and how high are the ears in your listening chair ?
What are the propagation settings you are using for the two mid's, tweeter ? Spike length, number settings for the spike rail ?
After recently re-doing my X-2 series 2 setup...1/4" in toe matters. I used lasers to get the correct toe.
Christian,
I'm on the road and can't give you many of those values until I return home, but the speakers are 123" tweet to tweet, and 153" from ear to speaker for Wilson ratio of 1.24. My question for you (or any big Wilson owner) is how much of the inside speaker cabinet can you see in the listening position? none? sliver? couple of inches? etc.
Marty
Great read Marty...
I will soon be adding 2 Fathom subs and CR-1 crossover and was told by JL that they recommend using a higher crossover point (around 90-95) to allow the subs to carry the extra weight so the mains can excel in what they do best. I'll give a full report soon on what I found out and everything about the setup.
Bruce,
You haven't said what you will be using the CR-1/subs with. May we learn that?
Learning to use the CR-1/Gothams with the S2s required patience and a willingness to experiment. As I said previously, when I first got the S2s, I was frustrated with their sound in the room as a stand alone speaker. Then I thought, hey, why not just run the system like I did the Pipes, using the CR-1 crossing over at 82 Hz, thinking this would get the "lumpy gravy" out of the bottom end since the bottom end performance would depend mostly on the Gothams as it did with the Pipes. And sure enough, it sounded pretty good. In fact, it was the first clue the speakers might actually survive my evaluation process. But what kept gnawing at me is that now what I had was basically the world's most expensive pair of mini-monitors on the world's most expensive mini-monitor stands! More importantly, it seemed I was throwing away some of the strength of the S2s which are its bass to mid/upper bass transition (40-120 Hz). That zone has always seemed superb to me in other installations. I attribute that to Wilson's efforts at crossover/voicing in that region. It was the area I could never get as "right" as I would have liked with the Gotham/Pipes using either a low level 144dB/octave slope crossover (TacT), or a 24dB/octave crossover (CR-1). Yet Wilson seems to have gotten this region right using a high level 24 bD/ octave crossover design. So I thought, why try re-inventing the wheel? Might as well try to set up the S2's more optimally in the room first to take more advantage of its strengths, and then add the Gothams at a lower frequency. I look forward to your experimentation. Happy to talk more about how to optimize the CR-1 as there are some tricks I have learned that you may find useful, but I don't want to bias your set-up now!
Marty
Same here on crossover...the overlap above 40hz does not work as well. I start to perceive a slight thickness to the bass which I do not need to fatten up those notes. The Wilsons are fine as is to that point...but below 40hz, the Wilsons alone (imho) just do not fill the soundstage with enough energy, slam or tightfisted pulse in comparison with the Velodyne DD18+ playing roughly 15hz-40hz in parallel with the Wilsons.
