Interconnect for My Kronos and Ref Phono 2se
StickMan451
36
Castle Rock, CO
Just bought a Kronos Limited with the Black Beauty 12" arm. Cartridge will be a Soundsmith Sussuro. Looking for some recommendations for a good interconnect. What do you like?
I'm very fond of the Transparent Phono cabling. I've also had good results with Purist and Cardas...
I've read several reviews of the Cardas Clear Reflection interconnects; sounds like a good candidate for audition. The Clear and Clear Beyond seem to be focused on 'clarity', not my first priority in a cable. I want a cable that gives a solid, full midrange, and all the harmonics and beauty found in female voice.
Might be worth trying a Purist Venustas or Purist Neptune. You likely will fall over backwards if in your system. Saying this from experience. Takes a little break in ( a few weeks) although at first listen you'll know it...
The Kronos designer, Louis Desjardins, recommended Kubala Sosna to me, which is what I use.
