You are proving my statement . Low output impedance is a figure of merit for amps. By raising it on the 200 watt amp, you are making it a worse amp and then saying synergy matters. That is exactly what I said. The lower the performance of a component, they more you have to find parts that work with it. Make the 200 watt output impedance .1 ohm and then tell me it is no better.A 20 watts amp could be better than a 200 watts if the 20 watts amp shows 0.1 ohm in output impedance with high current design and if the 200 watts amp has 2.5 ohms as output impedance.
And I advocate the more you have to worry about "matching," the more it shows weaknesses in a design. It is the easy way out to say I have designed an amp that only sounds good with this speaker and this cable. A lot of other designers work hard to make their amps work on broader set of gear. Let's not reward the ones that couldn't by turning a deficiency into a positive sounding word like "synergy."IMHO there are not simple answers to simple questions on audio synergy when we are talking on electrical matching subjects and its importance.
BTW, synergy in real world is far more than matching. It is 1+1 becoming 3. We know electrically that cannot happen in our world. So even if matching is something that has merit, it doesn't rise up to the definition of the word.
Again, I don't doubt that there are speakers that are hard to drive. But you can't prove "synergy" by saying an unknown 200 watt amp wasn't as good as the Classe. What if Classe had designed that 200 watt amp. Would you say that synergy existed more with the lower powered amp still?I can remember ( I owned both. ) the Apogee Scintilla's with a very low impedance near the 1.5 ohms where 200 watts amplifiers were not enough but where the Classé DR3-VHC amplifiers were almost the only amplifiers that works perfect with those Apogee speakers. Those Classé amplifiers were only 25 watts in class A but the VHC in the amplifier model designation means: Very High Current, current is what speakers ask on its load to the amplifier.
Your world gets complicated because you believe in synergy. That causes you to not believe in any other person's observation or tests because they don't mimic your situation across the board. I like to think that a box that measures extremely well, and was tested objectively to also sound better than other equipment it was compared to, will sound best in all situations. The notion that the amp that lost in such a competition sounds better due to "synergy" that all of a sudden clicked in, doesn't sit well with me. As a designer, that would mean that unless I tested my gear with infinite set of components, I can never know if I have designed something good. I see that as a troubled path .I understand what you mean but things are not so easy like that. In the other side we have to think that there is no perfect audio items where synergy is not critical, always exist trade offs and are these trade offs the ones that we have to choose and depending of what trade offs we choosed then at that level will be our system quality performance level: our system neutrality!
So again, it is possible to match something to another gear such that deficiency in one or the other doesn't become dominant. But all else being equal, I like to find gear that doesn't have such deficiencies.
Of course, if budget comes into play, then all bets are off. If I have to settle for a $500 amp, then I have choices to make. But if I can get a $20K amp, that trade off goes away.
