1- "AHEE" doesn't teach us that. The science of human hearing system teaches us that. Your ear is most sensitive in that region. Getting that right *is* the most important. Here is the Fltecher-Munson graph:
Whatever level of distortion you strive for, it needs to be lower for the mid-range frequecies.
2- I have not heard a single person say that all music occurs in mid-frequencies. So let's not state the obvious and say you are correcting others. What people say is that they value the fidelity of mid-range. Per above, there is good science to back that.
3- Mid-range is mid-range. *It* doesn't depend on anything. The entire music spectrum has other frequencies but what your ear detects as mid-range, would be mid-range even if you chopped off everything else.
4- You are inverting the logic and expecting it to be true. Just because someone says they love good mid-range, doesn't mean they want to hear highs at 20% distortion. They are simply saying that their mid-range sounds better than other systems like it.
5- Again, you are misunderstanding the statement. Assume someone takes your system and improves its midrange performance. Are you going to say there is something wrong with it? Again, you keep inverting logic and expecting to be true. Just because they say they have good midrange, it doesn't mean they have bad highs and lows. I have heard Steve's system. Its midrange is wonderful. But it is also quite good in other areas.
6- Well, in case of Steve, he is using a sub for low-frequencies. So maybe that is the formula to get good performance across wider range of frequencies.
7- You are declaring something as proof. There is a higher bar for the latter . Check this scenario:
I take a DVD-Audio source and run it through a dedicated Mark Levinson Dac. Then I run it into two versions of Stax headphones: one transistor and one tube. The latter sounds better. Is it your contention that the above system was so fault that the tube managed to hide more of its faults? If so, I doubt it very much . I buy the sound is more colored way before I buy the theory that tubes by magic hide all sorts of distortions.
Dear Amirm: It is clear for me that your ignorance level is different from the ignorance level I have . Anyway these are my answers on your post questioning what I posted:
1- Last week-end Alonso was the winner in the Korea Formula One Grand Prix!
2- I can't ( just like you do it here. ) post what the other people not said.
Anyway there are at least two persons in the thread that posted that :
+++++ " The midrange is where the music is. The midrange is everything. " +++++, this was posted by Tim ( # 129 ) and in the #130 Steve posted that agree with.
3- I can't understand exactly what you mean but the same you could say on every frequency range. Now, a 500 hz tone depends on nothing as a 32 hz tone, so what? are you hearing just tones?, IMHO what we have at home when we are hearing the audio system tell us that all frequency ranges depend each to others for a good quality perfromance listening.
The mid-range ( as I posted ) is the easiest frequency range to achieve the one that put lower demand to the system, both frequency extremes put higher system demands that are really hard to full-fill and that affect not only to the whole performance but to the midrange that is between it.
It is true that normally our ears/brain is more sensitive through the midrange frequency range but this " can't say the midrange is the most important where the music belongs ". Some of us are trained on purpose to " make " that our ears/brain be sensitive at both extreme frequency ranges at the same level than in the midrange. No not any one can do it: you have to be trained on purpose to do it.
4 and 5 - IMHO I'm not inverting nothing. A home audio system quality performance IMHO must be on equilibrum where no frequency range put your attention other what are in the recording. Please re-read my posts on the whole subject, I don't want to be redundant here.
6- Yes, subwoofers help if you know what to do with, if not could make more harm. The subwoofer subject is complex one, in this link I explain my take in this delicate subject:
http://www.whatsbestforum.com/showthread.php?1005-Multiple-Subwoofer-Placement/page2 , post # 16.
7- There are good and not so good audio item designs, who really can knows what happen with those Stax's set ups?. IMHO as an audio item ( like tubes designs. ) has higher distortions as more easy that that design hide other distortions that other designs ( SS) did not, this is not " by magic " but because the high limitations that " owns " tube technology.
Amirm, our each one level of ignorance in audio specific subjects is and was builded through our experiences, listening, reading, talking on audio, etc, etc. but some of us like to learn ( for different reasons ) on purpose some precise and specific audio subjects that our each one experiences ( it does not matters how wide/broader were it ) can't fill. To learn on a specific audio subject means an specific and in purpose training and only through this subject training you could understand in deep that specific audio subject.
Well, as some of you, I already have specific training in some audio subjects ( like the one about midrange. ) that permit not only understand in better way what is " happening " but to say that my level of ignorance is lower in that specific audio subject that the one of one person with out that in purpose training. For me the music/audio sound home reproduction is not only a great hobby but something else.
I know you are not on analog ( LPs reproduction ) but only as an example I already trained to detect quality performance minute deviations on cartridge/tonearm overhang and I can tell you that no one can do it but only the ones that were trained on this subject.
Right now I'm training on quality performance variations due to changes ( minute changes ) on cartridge/tonearm offset angle. This one as the " overhang " one extremely challenge subjects because we have to take in count that many differences in quality performance comes from VTF/VTA/SRA/AZ right cartridge set up and is extremely difficult to say which of those set up parameters was wrong and if we add overhang and offset angle well ..... only if you are trained.
To achieve these kind of audio subject targets/knowledge you have to have your own training process that you will " fine tune " through your experiences. This kind of training process made that you will be ( by your self ) the best " tool " you have on hand to improve your music home happiness.
One tool that help me a lot through each training process is that I already defined/choosed very precise LP normal music recordings tracks ( around 12. ) that I always and I mean always use it for any system subject audio training or any audio system ( and I mean not only mine. ) overall evaluation.
So I don't hope you agree with me, this is not the target of this post and what I already posted it is only what I know is " happening " and that sooner or latter will " happening " to you if you take that road.
Btw, I'm not alone in the midrange subject as you can read through other people posts there are other advocates that some way or the other agree with.
Yes, my ignorance level in several specific audio subjects is higer than yours and from other people: like digital source where I need to learn and " take " a training in the digital areas that could be of interest for me and yes there are many other subjects where I'm almost ignorant.
I always said that every single day is an audio learning one: especially through audio forums like this one with so many experienced people like you are.
Regards and enjoy the music,
Raul.
