Hello Micro
I don’t think it open pandora’s box at all. I am no stranger to burn in but what are we talking about burn in for electronics of mechanical break in like a loudspeaker. The effects of burn in on electrical components is well understood. There are easilly measureable differences. If you look at the part screening specifications for these parts used for space and military applications there are even delta requirements for selected parameters that if you exceed them the parts cannot be used. There are always shifts but that does not mean they would be audible if used in say an amplifier as an example.
Now with speakers 500 hours of burn/break in?? The only you are breaking in is your mind IMHO. With materials you have beryllium, aluminum, magnesium and titanium used in compression drivers. They are all different in their properties. I like beryllium best. I don’t see it as pandora’s box. Under certain circumstances and uses there will be audible differences but not in all. That is where I make the distinction.
Hello Folsom
I use the older battery method.
Rob
Rob,
You use a dual criteria - you seem to accept that DC biasing improves the capacitors without providing any measurable or scientific evidence - the arguments about similarity to class A /Class B amplifiers are nice literature, but just marketing analogies. Did you read the Greg Timbers comments, that are purely subjective? They are the best we can find about this affair.
There is no burn-in military specification that can be applied to our subjective findings abut components. The best I found was a document about endurance from the 50's that suggests that film capacitors subjected to DC endurance tests seem to have a lower failure rate in the future, but it was not proven.
Part screening and infant mortality are different subjects that use proper science and analysis.
