The first amps to try on the Hailey 2s will be the Ampzilla monos, designed by the late James Bongiorno:
https://www.sst.audio/ampzilla-1
They are quite reasonable, quite powerful, and allegedly warm, tube-like SS. In my journey so far, I feel YGs need 400 watts into 4 ohms minimum. Bongiorno also didn't believe in audiophile power cords, so they are welded in the chassis![]()
I think important to mention that his music first passive preamp is zero gain. To actually understand what the Luxman and the AR are doing you will need to try other preamps.
It has to be said that Keith has a very, very peculiar set up, with a passive preamp AND long cables (among other things), which makes amplifiers perform uncharacteristically there in his system. I understand that particular setup worked wonders for his DeVore, but IMHO, it's not ideal for his new speakers.
I invite folks to come to the store to hear the Luxman and the ARC 160M on Sonja 2 (bigger than Hailey). They are not as described by 213Cobra in our systems, in a much, much larger space. As I made perfectly clear to Keith, both amps performed uncharacteristically in his system, and I can only think that's because of his unique setup.
Now, the LAMMs are a great match electrically to his passive pre, so hopefully Keith will score a pair and we'll get to the bottom of it, as I'm curious myself to hear LAMM on YG.
From Rafe Arnott's report on our room at last year's THE Show, that featured Hailey 2 and Luxman m900, but with an Audio Research REF10 and different cabling:
https://www.audiostream.com/content...udio-impact-msb-technologies-and-yg-acoustics
"Add in no break-up to Plant’s gated-mic vocals and palpable texture to Page’s and Jone’s playing without slipping into distortion – a real feat for this recording at high volume in almost any system and I was pushed back into my seat with satisfaction. Midrange had slam and impact, with just the right amount of juice to make it chewy without becoming bubblegum.
Speed and attack on notes was worthy of the musical pace of this cut and with all the stereo panning going on, the sound stage is stretched wide and can be disparate, but here the cohesion remained unflappable."
More power would've been nice, but we clearly were reaching the room's ability to play loud (overexciting it) before we reached the amp's.
So, no, I don't agree you need 400W on HaileyAt least not when used with an active preamp!
It's not the wattage alone. It is in the particular amp output/speaker input interface characteristics, and these vary widely in crossover-based speakers. With cleaner high power volumes, the room was not inducing the smearing. Now I think the M160 and the m900u are excellent amps in the right systems for them. It's no foul for a combination not to be optimal even if the individual components are otherwise excellent.
Phil
I agree. I am never a friend of passive preamp. I think he should borrow active preamp to try.Did you read what I wrote? Same amp, same speaker, different preamp and cables. MUCH larger room. Result? Dynamics.
Anyway, I just wanted to point out the elephant in the room
Keith just needs an amplifier that's more compatible with his TVC preamp, that's all. Neither the Luxman nor the REF160 were. To me, that's all there is to it.
I think there was a mismatch with the ARC 160m and the Music First TVC. The ARCs input sensitivity is only 2.4V (half the sensitivity of my Ref75SE even).
Also, I'll add that two other listeners this past week soft clipped the amp at loud levels - that doesn't seem like a gain issue.
