@bonzo75 could you name some options?
Just to clarify, there is no such thing as retip with Koetsu Japan. Much like Lyra. Long ago I had emailed Stig Bjorg of Lyra about a possible retip of a cartridge he re-worked on. He described the process as rebuilt as well, and the price was eye popping even for those times. He considered the late Sugano as his mentor and on the same line of thought, repairs a broken cartridge by rebuilding it. Which now makes me wonder, with the many people of companies that do retip only, if you ask for a retip only job, do they just retip it and return it to you? I mean, without opening the body and checking the alignment or condition of the other parts? Usually, when a tip disappears, there was a physical trauma on the whole cartridge, meaning, it is highly unusual for a top tier cartridge to have a diamond stylus fall off by itself. So after a 'retip' job (simply replacing the diamond stylus), if the performance is not at par as when it was new, what happens? (ie. alignment problems from the inside of the body). I am asking this because I do not know the procedure of a retipping job.but it’s a good thing you paused when you did, at silly retip/rebuild prices
Thanks for the input, Bonzo. I now get the picture.that depends on the design of the cartridge. The top wing red sparrow design, for example, has wiring inside the cartridge body and the cantilever can be easily disconnected and the stylus replaced cheaply. From users this has caused no issues with the sonics and they got back sonics like before, no drop in performance. With vdh you are going to get a different alignment irrespective of whether you retip or buy new. Vdh is great at the servicing users at low prices so that they can get their cartridge sent back to vdh to get it inspected, realigned, or output changed . Dava guy is just friendly to his customers and if damaged he will send back the cartridge retipped fixed at virtually no cost. Both my friends were delighted after it came back. There is no drop in performance.
Read this Koetsu Blog I can say that it was very helpful and informative. I could understand many statements when I heard Koetsu pickups or installed them myself.@bonzo75 could you name some options?
Indeed that is a very informative blog. Thanks for posting.Read this Koetsu Blog I can say that it was very helpful and informative. I could understand many statements when I heard Koetsu pickups or installed them myself.
The Koetsu story – Japanese art Part I
There is something special about Japan, tradition and modern high tech are often separated with only a very small distance from each other. The attention to even the smallest detail in some …medialux.blog
When you want read more about koetsu or lyra ,in german analog forum is Ekki (username "querstrommotor"). amazing good threads, sad he is not more active there.Indeed that is a very informative blog. Thanks for posting.
Now this is a rare one.Custom early Sugano Urushi diamond cantilever platinum coilsView attachment 107188
Really beautiful !Rare White Jade custom built diamond cantilever platinum coilsView attachment 107193View attachment 107194
Is it okay if I give you my address, so you know where to send them, hahahaDarker colored & nicer looking Coralstone D was bought 2 years ago. Lighter colour coralstone D just took delivery today . Wanted another one but unfortunately limited
Sure . Just send me the moneyIs it okay if I give you my address, so you know where to send them, hahaha??!!
/ Jk
Here's a somewhat related but not often discussed question: it's proven that VTA adjustments will change cartridge alignment/offset. Is it important to re-check alignment after even small VTA adjustments?I don't doubt this at all! But I am not asking the question of whether or not the owner is happy with the sound. The question I always ask is whether or not the cartridge has been mechanically optimized in order for the stylus' contact edges to trace the groove in the same geometric alignment with which the cutting stylus made the groove in the first place. Of course, the subjective performance difference between non-optimized and optimized always favors the optimized except in those very rare occasions where the misalignment was hiding a problem elsewhere in the system that suddenly becomes noticeable. This has happened to me a couple times but the systemic problem to be fixed can be found with good electro-mechanical system and analysis.
The sound between a mis-aligned cartridge and perfectly aligned one is NOT the difference between "bad" sounding and "good" sounding. For example, stylus misalignment is NEVER a cause of mistracking - it only makes it more likely to happen when the tonearm is out of control or the stylus is dirty or VTF is too low.
Good point. If you raise (or lower) the VTA and the sound is favorable to you, but in effect it alters the other parameters of the alignment (which has an ideal set point via protractor or microscope), which set point will you choose? From what I understand, the VTA is subjective, with a straight or parallel line to the vinyl as 'normal' setting.Here's a somewhat related but not often discussed question: it's proven that VTA adjustments will change cartridge alignment/offset. Is it important to re-check alignment after even small VTA adjustments?
Also related to this is that arms with the ability to alter VTA 'on the fly' typically have increased play which will again affect alignment. So you are not really changing only VTA!
