The choice between PX4/25 is clearly a gain play. The PX4s seem to be the best and safest choice for those who are buying blind. They do everything. Great for rock, classical, vocals, cello. They place the choir back behind the speakers wide across the room like it should be. Greg's DIY horns and Yamamoto are very high gain. The PX25 initially had a superb grip on the piano and the cello in Beethoven's cello sonata. On other tracks we were getting too much hardness so Greg reduced his preamp gain by inserting tubes 3db lower. Then the difference between PX25 and the PX4 dropped. So, in other words, please don't read here for advice on whether to buy 4 or 25. If you can't hear both, buy 4.
The Special EML Lampi Globe anniversary 45 did some things better...but only if you were critically listening, and had to write a review, and pick one of the two. Otherwise, they are so close, if you have one and don't want to spend on the other, don't. You are not losing out on any quality or drastic presentation differences that might suit your preferences. The 45 did highlight some of the individual instruments in large orchestral passages better.
In Greg's system the EML mesh 5u4g recti worked the best with all these tubes. It gave a slight air, and timing pause, while the special KR 5u4g sounded too aggressive and rushed. But then in some systems, the EML sounds too laid back. I would still take the KR as the safer bet and if it sounds too rushed, switch to EML. EML has more air.
The Elrogs do their own 300b magic but I don't seem to be a 300b fan. None has worked on me. I think if one has to spend on one output tube, it should be the PX4 or the special 45 depending on your budget and the 45 availability. Greg is in agreement like with last fortnight's rolling group. Bill's system will be worth confirming this in as it is a very different system - SS, big cone speakers.
Sujay, who reluctantly got into Lampi because he was dissuaded with digital, now has ended up with both PX4 and those special 45s in a balanced Big 7 and the KR 5u4g. Talk about beginners luck!
The 101d and 104 were not used in months and were taken out cold. Both have a warm, embracing feel, but more laid back and less dynamic than the modern valves. The 104 is more dynamic than the 101. What they had over the modern ones was a pause and time interval in the music, making the modern ones appear more rushed. They had a more traditional tubey sound.
