Asking Price: $4,400.00
New Retail Price: $9,500.00
This was a trade up to our Veritas Monoblocks.
There is a very light scratch on the left upper side of the silver area on the front.
See photo "Scratch". You can barely notice it depending on the angle and light.
Unit works perfectly. Serial No. 29914060038
Original Power Cord, Manual and Box included.
Duo 300, ?2 Channel Power Amplifier? 300 Watt Amplifier Featuring Krell iBias Technology
??Specifications:
Frequency response?20 Hz to 20 kHz +0, -0.13 dB?0.5 Hz to 100 kHz +0, -3 dB
Signal-to-noise ratio?>98 dB, wideband, unweighted, referred to full power output?>116 dB, "A"-weighted
Gain?26.2 dB
Total harmonic distortion?<0.045% at 1 kHz, at 400 W, 8 ?*?<0.17% at 20 kHz, at 400 W, 8 ?
Input Impedance?Single-ended: 100 k?*?Balanced: 200 k?
Input sensitivity?Single-ended or balanced: 2.4 V RMS
Output power?300 W RMS at 8 ??540 W RMS at 4 ?
Output voltage?138 V peak-to-peak?49 V RMS
Output current?16 A peak
Slew rate?40 V/?s
Output impedance?<0.017 , 20 Hz to 20 kHz
Damping factor?>470, 20 Hz to 20 kHz, referred to 8 ?
Power consumption?Standby: 4 W?Idle: 180 W?Maximum: 1600 W
Heat output?Standby: 13.7 BTU/hr.?Idle: 615 BTU/hr.?Maximum: 5677 BTU/hr.
Inputs?2 single-ended via RCA connector?2 balanced via XLR connector
Outputs?2 pairs binding posts
Dimensions?17.1 in. W x 7.65 in. H x 21.10in. D?434 mm W x 194 mm H x 536mm D
Weight?80 lbs., 3.64 kg (shipping)?70 lbs., 31.8 kg (unit only)
Here is a Review:
http://www.absolutesounds.com/pdf/main/press/KR_Duo300_HFN_Octo14.pdf
Here is a Link for More Info:
http://www.krellonline.com/stereo-amps.html
We appreciate you browsing. Happy Listening! www.merrillaudio.net
Or call us with any questions 415 5-MA-HiFi (415.562.4434)
??Specifications:
Gain?26.2 dB
Slew rate?40 V/?s
Here is a Review:
