Are there any other apendages that they can make bionic for better performance? Asking for a friend.They'll have you up walking 1 hour after the surgery. I have bionic knees. it was a life liberating event. You'll be fine
I am on the verge of ordering a Horizon.
As my amp is a single ended design, I would use the Horizon in SE mode.
Would that mean that I would not exploit 100% of the sound quality the Horizon can deliver?
+1 on thisSounds great either way and, with your amp, probably better in SE anyway.
Simone, SE is fine. I run Balanced, others do too, but I seriously doubt you will be disappointed running SE. I would bet more run SE than Balanced...JohnI am on the verge of ordering a Horizon.
Agreed. It’s all about synergy and what the best performance mode of your amp is. I have used it in both modes and there’s not much difference. The amp’s preferred mode is going to be the much larger factor.Sounds great either way and, with your amp, probably better in SE anyway.
Edit - I have the same amp, have tried both and SE will be better for your taste.
I took the plunge and ordered the HorizonI am on the verge of ordering a Horizon.
felice per te Simone!! Molto eccitante!! JohnI took the plunge and ordered the Horizon
I listened to it in few occasions, the most recent being at Taiko HQ a couple of weeks ago in combination with both the Extreme and the Olympus prototype. Never in my system though, as a home demo was not viable, so fingers crossed the upgrade over my dCS stack will be worth the investment
I will be getting the XDMI interface, as the Olympus would be my logicalnext big step when my wallet will recover.
Exciting times!
So excited for you!! This is going to be a paradigm shift esp with XDMI.I took the plunge and ordered the Horizon
Exciting times!
Congrats on the purchase of the HorizonI took the plunge and ordered the Horizon
Exciting times!
Generally tube preamps and DACs etc. have rather high output impedances compared to their solid state counterparts. A tube preamp may have 3-5 kohms whereas most solid state preamps have 20 ohms or so. There are of course rare exceptions to this rule. I recently got a Conrad Johnson GAT S2 tube preamp that has around 600 ohms output impedance because it has a solid state output driver section. ARC preamps are happiest into ARC tube amps that have input impedances of 100-200 kohmsHi guys. I am using DSP crossover and an AD converter card from Merging Technologies to convert my LP analog to digital for processing. For my digital side, I am using Taiko Extreme and in the past, I use the digital output of Extreme to connect to my dsp crossover but it isn’t possible anyway and has to go through a DAC. I am thinking of Horizon. My question is that the AD converter has an input impedance of 10Kohms and I am worried that it is too low for Horizon. Any comment?
We just need the secret 66 volume setting to go with that for the best SQ…The tidbit of the day......
For those awaiting either an Horizon XDMI retrofit or a new Horizon with XDMI, the XDMI input on the Horizon remote will be number 6
