anyone heard of the TRP 4, mentioned in the Q1 2024 SQ ranking in the price list? Is this a TRP with E11P?
I got the info from Poland, that TRP 4 is the actual TRP with E11. So TRP 3 is the predecessor with E53. At least I can confirm, that my actual TRP with E11 and JL USB is quite a bigger step up in SQ, compared to TRP 2 with E53 and Amanero USB.You might try your national Lampi rep or Golum or write Lukasz directly.
Maybe a new naming for 2024? I received my new Atlantic TRP 3 with Golden upgrade just shy of 4 months ago and at the time there was no mention of an Atlantic 4 version. The standard configuration was E11 and JL USB as E53/Amanero were already things of the past at that point.Probably not, TRP 4 is with E11 and follows the naming conventions of the Baltic models, Baltic 4 has as well E11. But the website still shows TRP 3 with E11.
More sloppy naming conventions from Lampizator for the Atlantic? In my recollection, there was the Atlantic, then the TRP 2 was really the first TRP (which had engine 53), while TRP 3 is the latest (has engine 11). I remember having to sort out some of this confusion (because of conflicting names on the website) when I purchased my TRP (2) w/ engine 53 a few years ago.My TRP 3 upgrade from 2 was to get the E11. Same with GG 2 to 3. Perhaps TRP 4 is the P version?
Although that might be cool the upgrade sheet states “P” is only for the Pacific and Poseidon.My TRP 3 upgrade from 2 was to get the E11. Same with GG 2 to 3. Perhaps TRP 4 is the P version?
Actually, Engine 11-P is a version of Engine 11 first specifically developed as a digital engine upgrade for the Pacific, not Poseidon. Engine 11-P came out before the release of the Poseidon. However, Poseidon does have Engine 11-P.
The upgrade cost for Engine 11-P is double that of the upgrade cost for Engine 11 and more elaborate/higher performing (4,000 euros vs 2,000 euros). I don't believe Engine 11-P is available for any Lampizator model below the Pacific (GG, B7, Atlantic, Baltic, Amber can't be upgraded to 11-P).
I need to correct the bolded text in my previous post:
I just looked more closely at my spec sheet for my GG3, and it has Engine 11-P installed (not Engine 11). So, this digital engine version is an option for GG.
Moral of the story- When in doubt, refer to your DAC's birth certificate, not the website info.![]()
