?????? ?????? ??????? 5c3sWhat tube is that?
Could someone explain the difference between
Tungsol 6SN7 GTB and the
TS JAN CTL 6SN7 GT ?
Sonically?
Will they really sound much different? Similarly priced it seems. I bought the 6SN7 GTBs a while back. Apparently I ordered the wrong ones.
What is the significance of the JAN CTL and most importantly the extra B behind GT?
And if they are almost the same tube at the same price why would a company build so many variants that apparently fit the same sockets, and can be interchanged electrically?
I don’t know much about tubes and all the mysterious black plates, square getters, side getters, triple mica and many other variants than I could ever hope to list are interesting and one wonders why? Is there a book somewhere about the history of vacuum tubes and how they evolved
Psvane CV181 won’t be in the same zip code as old Mullard CV181 (ECC32), but probably ok.Wow. Thanks. Lots of good information. Now I’ll be an expert too. At least with 6sn7 tubes.
I wonder how the PSvane and other new equivalents compare to the older tubes? It seems like they are not held with the same esteem.
How do the VT99 tubes compare to 6sn7?
My Dude preamp used 12sn7s. Can they be used in Horizon and anyone using them?
I went from Lukasz favorite the Bendix 6900, then the Thomson 5687 and finally the TS 6SN7 GT CTL 231 round plate and dark glass. In my system it’s everything that it wasn’t in your system. I stopped rolling there and have found 3 NIB matched sets. So yes it is system dependent as well as one’s preferences. One man’s passion is another man’s poisonI tried the TS 6SN7 and found them dark, with slightly loose bass. I found the metal base Sylvania 6SN7 much better In the Horizon, at least in my syStem. I highly recommend these Sylvania metal base. They are an excellent tube.
Indeed, certainly system dependent, but I also took these TS 6SN7 up to my headphone amp (Cayin HA-300) and found the same issue. I am not saying these are bad tubes or that they are super dark with loose base, but relatively so. They are dark and loose on the bottom compared to the Sylvania metal base and the EEC31 w/adapters that I have here. This is true in both systems and is relative. The TS are certainly better than Psvanne, RCA and other tubes I have here, but they are a tad dark and the bass is loose relative to other tubes. I also have the TS VT99s with Woo adapters and they have the same issue. I recommend trying ECC32 and Sylvania metal base. You might be surprised by both/either of them. I could be dead wrong (wouldn’t even be the last time today , but I would wage that if you compare ECC32 or the Sylvania metal base they will stay and TS will go….I went from Lukasz favorite the Bendix 6900, then the Thomson 5687 and finally the TS 6SN7 GT CTL 231 round plate and dark glass. In my system it’s everything that it wasn’t in your system. I stopped rolling there and have found 3 NIB matched sets. So yes it is system dependent as well as one’s preferences. One man’s passion is another man’s poison
the other thing that you haven't mentioned is the synergy of the 6SN7 with the other tubes used. I strongly disagree about your comments about the bottom end of the TS being loose. It just isn't the case in my system. What I look for is NOT something that stands out but rather top to bottom linearity To me if something is standing out, it is coloration and that is not part of my systemIndeed, certainly system dependent, but I also took these TS 6SN7 up to my headphone amp (Cayin HA-300) and found the same issue. I am not saying these are bad tubes or that they are super dark with loose base, but relatively so. They are dark and loose on the bottom compared to the Sylvania metal base and the EEC31 w/adapters that I have here. This is true in both systems and is relative. The TS are certainly better than Psvanne, RCA and other tubes I have here, but they are a tad dark and the bass is loose relative to other tubes. I also have the TS VT99s with Woo adapters and they have the same issue. I recommend trying ECC32 and Sylvania metal base. You might be surprised by both/either of them. I could be dead wrong (wouldn’t even be the last time today , but I would wage that if you compare ECC32 or the Sylvania metal base they will stay and TS will go….
Can you post a picture of the Tung Sols?
whose....mine or SampanjannaHmm... those look quite different than my TS JAN CTL 6SN7 GTs...
which are incredible... and leave nothing wanting in my system (especially in the bass).... w/ their pairing of course.
