The Philco ST shape 01a’s are the quietest tube I have had in my Lampi B7 - by a large margin. It isn’t even close. Maybe I just got lucky and got an extremely well matched quad-not sure. It is spooky quiet-and it isn’t due to lower gain either like with the NU 45. The Philco’s gain is comparable to the Cunningham 01a globe, the stock Shuguang 300b-98, TJ-300b, and slightly less (2db) than both the globe and ST shaped 112a.
My noise test is thus: I flip tubes in my quad until (by ear) I get the lowest noise at max 0db volume setting without signal - then I measure the noise level with an SPL meter placed on the floor and touching the center of the loudspeaker -both L/R measurements. Up ‘til now I was getting at lowest 60-65db (more than acceptable and inaudible when you adjust the volume to normal levels).
With the Philcos the noise is basically zero- it is way below the threshold of my SPL meter and I barely can hear just a slight hiss/buzz even with my ear to the speaker at 0db volume. We are talking several orders of magnitude difference. Like I said before, maybe it’s just a lucky match with the quad, but Simon at diyhifisupply matched my TJ 300b’s ,and sent me graphs etc, and those were no better and in line with the 60-65db measurement described above.
They sound great as well. -definitely worth a try.
