Yes, very interesting article, thanks. Scary, but I may try baking the 596 if the crackling continues.
Not that i found any - China is the only source you can get those adapters from afaikI was able to “smuggle” a pair of match px25 out of Japan and otw to me now. Anyone can recommend someone selling a good B4 to UX4 adapter, ideally out of teflon?
Thanks.
Thanks.
I use these. Heavy, quality item. The Philips screw in the base can work lose but it's easy to tighten. Just make sure they are tight when you get them and you probably won't have an issue and if you do the solution is obvious.
https://www.ebay.com/itm/201564717131
Which PX25s did you get?
WhichI use these. Heavy, quality item. The Philips screw in the base can work lose but it's easy to tighten. Just make sure they are tight when you get them and you probably won't have an issue and if you do the solution is obvious.
Haltron branded MOV.
Also buddy suggested I buy suzier on eBay for Px25 adapter. I do like that it is a Teflon body.
https://www.ebay.com/itm/PX25-CV104...616292?hash=item48b0d86264:g:UBkAAOSwFFxekTWk
Love my Psvane Acme 274B on my Pacific.Question for you seasoned Lampi tube rollers. I was thinking of picking up a good 274B to compliment the KR 5U4G for the Pacific. I looks like some of you like the PSvane ACME 274B. I also notice the PSvane has a 274B-TII with carbon coating on the inside to getter stray electrons. anyone compared these two or should I look elsewhere?
Thanks
You got them finally?!? Yeah - really happy for you!
Regarding the view on them - you won't pass with just one sentence
