Disclosure: I listened on headphones via computer. The sound there can be decent on actual professional recordings (not iPhone system recordings). So it's not that my playback completely sucks. It's the recording that sucks.
This might be the problem, what was recorded on the Iphone, should be listened on the Iphone. Also, when listening on YT, compression levels vary constantly, you never know what it is you are hearing. Which can explain the different reactions to the same video.
Edit- The purpose of my comments isn’t to knock the speakers I’m bringing up the importance of setup and the system driving them which is critical specially at this level. Low impedance power hungry speakers are a handicap from the get go.
Nonsense, like everything else, there are tradeoffs. BTW, the M9s are 94db efficient, with an actively driven bass section. Should be fairly easy to drive.
Nonsense, like everything else, there are tradeoffs. BTW, the M9 are 94db efficient, with an actively driven bass section. Should be fairly easy to drive.
The M9s do NOT have an active bass driven system. Although they do have their own outboard dedicated amplifiers. Two channels for the top modules and two channels of amplification required for the bottom modules. All four channels come out of the MXO crossover.
The fact that the MXO crossover handles separation between the mid-bass and the bass section of the M9s I believe will prove to be a real factor in the performance of the M9s. I can't wait to get my hands on them. AND with my amplification.
The birds on the recording are kind of funny. I can see how people like them or dislike them but to me they sound far from convincing. I think they are distracting from the sound of the strings.
To me the sound is homogenized. It’s flat and sterile. Very pleasant sounding music but the presentation is lifeless.
It’s not the case that all videos suck. There are some good sounding videos posted by people. I don’t think much can be gleamed about these particular speakers in this context but I appreciate that the video was posted and shared. It is clearly meant to be a showcase system to give pleasure to the owner.
What trade off when one is limited to expensive very high powered amplifiers that aren’t natural or musical sounding? You’re stuck with that.
As I mentioned clearly I wasn’t commenting on the M9s but the cause of the problems heard that has nothing to do with speakers.
94db is just one parameter and only a number, how that measurement was made matters and you need more information on how the speaker behaves under load to make any conclusion on the speaker’s real efficiency.
A nominal sensitivity spec can be of limited meaning. My two-way monitors of 92 dB sensitivity (supplemented by active subs) can easily and very dynamically be driven by my old 15W/ch parallel push-pull triode monoblocks. My current tube amp is 100 W/ch. Overkill, like I wanted.
Yet reasonably efficient two-way monitors are easy. Large multi-way cone speakers are always harder to drive.
Yet two-way monitors are easy. Large multi-way cone speakers are always harder to drive.
No thats not my expirience .
2 ways are the hardest .
Its almost impossible to design a high eff easy to drive 2 way speaker
I can see where david is coming from .
But alon wolf has made different choices
You lost me here, sorry. Your definition of ‘natural or musical’, based on the videos I have heard of yours (and Peter’s set up), is extremely colored. Like I said, there are tradeoffs to consider, and personal preferences.
I have looked it up and according to stereophile it has a 5 inch woofer and a soft dome .
Al , seriously such a design is very limited
Its hardly capable of doing any damage
Correct. Its physics, a small 2-way, efficient, easy to drive speaker will have no bass (unless it is really big). The lower you want it to go, the less efficient, or the bigger it will have to be.
Thats also not the case cannata look at the wilsons ( X 1 , X2 ) for example
But believe me alon wolf knows exactly how to make a easy to drive high eff speaker .
Its just that he has different design ideas/ priorities
But then, I think all speakers need subwoofers. The generic term "full-range" speaker for any multi-way floor stander is a pathetic joke. Very few speakers are full-range.
Put on some deep bass electronica, and you'll know right away.
