Maxx 3
rockitman
7,097
414
1,210
Northern NY
will Pass Labs XA 100.5's adequately power the Maxx 3's ? I am currently running W/P 8's w/o power/load issues. Would have them in a small well trapped room 16x16x8. Looking to hear from Maxx 3owners. From what I have read, the Maxx 2's were a more demanding load than the newer 3's...
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
will Pass Labs XA 100.5's adequately power the Maxx 3's ?...
No..... My 3 choices were the Maxx3, ISIS and the Focal Maestro. The ISIS was the hardest to drive and really didn't open up. The Maxx3 was better but turning up the volume, the amps meters were bouncing like VU meters and the sound felt constrained.
rockitman
7,097
414
1,210
Northern NY
hmmm, conflicting views. Are Alexandria's easier to drive than Maxx 3's ? If I needed more watts for the Maxx 3's and didn't for the Alexandria's X2 series 2, the cost differential is almost a wash (buying lightly used X2's). Is my room too small for Alexandria's ? I suppose I could go the MM2 route since the bass is self powered...
IMO your room is indeed probably too small for X-2's and yes they are easier to drive than Maxx lll's. I am using a 32 wpc amp to drive my X-2's
I do believe your Pass amps will drive the Maxx lll's better than your WP 8's as the former are more efficient.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
IMO your room is indeed probably too small for X-2's and yes they are easier to drive than Maxx lll's. I am using a 32 wpc amp to drive my X-2'st.
The EA MM3's are exactly the same size as the X-2's and they work in my room really well.
FrantzM
29
405
Not A Wilson owner
Ia a room can take a Maxx-3 it will take an X-2. For the money I would have taken the used X-2 ... I have heard larger speakers in room as small as Rockitman and they fared well.. Room were very well treated with diffusion and Bass traps ... And I am fan of big power even when the speakers are efficient which the X-2 surely are (94? 95? dB/w/m) ... I would not pass a used X-2 for a new MAXX-3
My $0.02....
you can buy new X-2's at Paragon audio in almost any color for $75K
X-2's in a smaller room IMO would sound bloated even though they are front ported. X-2's are 95 db efficient
Maxx lll's are 91 db efficient and WP 8's are 92 Db efficient
rockitman
7,097
414
1,210
Northern NY
This is the crux of the issue for me. I am happy with the volume levels I achieve with my 8's and the amp's really don't break a sweat. If the Maxx 3's are truly an easier load than the W/P 8's, they are a conceivable upgrade for me. I'm not really interested in buying new more powerful amps. If I could get away with the X-2's in my 16x16x8 room at their current used going rate...I could have some sleepless nights ahead contemplating whether to purchase those monsters or not. I sit 9 feet away from my 8's right now.
I sit 13 feet back from mine
4,702
My $0.02....
I think no one would do it. Also I know some current owners of Maxx3's are selling the Maxx3 cheap to get an used X-2 ... ;)
Frank750
821
1
928
I'm listening to Pass XA100.5 driving my X2-2 right now while my ARC Ref 610s are back at ARC. No problem what so ever, although I don't listen very loud. I think if you look at some of the rooms you can see in on line pictures you'll see Alexandrias in rooms the size of yours. I had Grand Slamms in a 17 x 14 room for years with great results. I'll bet you can get an upgraded pair of X2 fresh from the factory for $55K, maybe less at this point. Mine will be gone next week at this time too.
LL21
14,430
2,518
1,448
i vote X2. I have heard X1 and X2 in small rooms, and when properly set up they are tremendous. As wilson will confirm, properly set up is all the difference. I spoke with Peter McGrath last nite, and we both agreed that the main reason my X1s sound so good is because of the 2 guys who set them up, namely the GM of the Distributorship who really knows his stuff...and whom both Wilson, Transparent and other major names consider to be best-in-class in knowledge, experience and technical expertise.
If you get the X2, i doubt you'll regret it over Max IIIs particularly for the money, and i am told one of the [many] reasons for the reconfiguration of the X2 woofer (originally from one of their subs i believe) was that it helped integrate the speakers a little bit more easily into smaller rooms for the Asian and European markets.
rockitman
7,097
414
1,210
Northern NY
now I'm really starting to get speaker distracted....I have Alexandria on the brain....
LL21
14,430
2,518
1,448
...know the feeling! i am thinking about 2nd hand transport...which i have been hunting for at the right price for nearly 5 years since getting the DAC! Enjoy!
FrantzM
29
405
The vote goes to the X-2 !
mep
17
Unfortunate set of dimensions. Multiple of 8 feet in all three dimensions means some really nasty and non linear response in the bass. LOTS of bass trapping and room correction will be necessary to extract the most from whatever speaker you use.
I was thinking that, but I kept my mouth shut. A perfectly square room with the ceiling being exactly one half of the other two room dimensions is not on anyone's list of qualities for a good sounding room. But, we all have to play the cards we are dealt with.
