I can certainly hear the difference between their previous beryllium tweeter and the newer silk dome. ... or, dagnabit, maybe I'm just hearing the marketing. My wife calls me 'eagle ears'.
Eagle ears and bat eyes?
There you go Ked simplifying things down to a Wilson analogy.....fruit bats have really good eyes and no echolocation like other batsEagle ears and bat eyes?
My vintage speakers from the 50s seem to be able to play very loud with little strain and minimal distortion. At least to my subjective perception. I don’t know how much power they can handle but there seems no reason to find out when they operate beautifully on a few SET watts.
It sounds to me like increased power handling ability has become necessary with modern speaker designs. I don’t know if it’s an advancement or simply a response to modern speakers. I suppose it depends on your perspective. Thank you for your response.
Holy moly.classic amplifiers.
I don't recall eagles' hearing being all that good, certainly not like their eyesight.
the rectifiers shine so beautifully 1000watt from sixtiesthe little early 50-ies backup Klangfilm amp (KL204a) I'm currently using already pushes out 7 Watt (Single ended), 3 watts typical power output was likely more going back to the thirties.
Spectacular light show.the rectifiers shine so beautifully 1000watt from sixties
the philips amp runs 3500v anode voltage, the output transformers are filled with wax for insulation. Amazing buid in the sixties.Nice, my new tube amps also use mercury filled rectifiers (work in progress) but they won't put out anything close to 1000Watt.
which tubes are used? I am clairaudient thenNice, my new tube amps also use mercury filled rectifiers (work in progress) but they won't put out anything close to 1000Watt.
had the transformers left over, something built quickly, if you take Pl 519 then telefunken are more stable. Have fun and good luckActually, the Anode is only there for show in this design...we'll be using the screen as mesh anode ;-) following Cees Brakenhoff's find.
What was the application of this amp?the rectifiers shine so beautifully 1000watt from sixties
for stadiums or large events, class b 1000 watts 8/16 ohms. I know someone who converted it to 340 Class A triode watts. sounds goodWhat was the application of this amp?
david
