There's no mystery. I've heard this directly from Larry @ MSB. He said there's no conversion. It just decodes DSD via software.
Since MSB doesn't use off the shelf parts, they're able to program the DAC to do whatever they want, and since the DAC runs at a fast enough speed, they were able to program it to decode DSD, via software, in 2 days.
Since dCS also has programmable DAC modules, they're also able to add DSD to their DACs via software. dCS' limitation is actually in hardware, in which they rely on specific ports for receiving the signal (USB, Firewire or dual AES), while MSB can handle up to 2xDSD on any port.
It's commendable what some people can do with off the shelf DAC chips. But, in my experience, rolling your own DAC modules give you a lot more flexibility, not to mention much better SQ overall. Heck, you can even custom order specific filters for your DAC IV, since they're also all software-based.
alexandre
alexandre
