My new ride !!
Hi guys. Not much new here. Waiting for local store to come pick up my long pre amp wire to be retuned from ar pre to dag. Added a middle audio diffuser but will be calling new room guy for measurements and treatments if need it.
Room looks so great! So you decided to go for the Momentum HD preamp then?!!
Marc.
Plus my ar left output channel is dead. That needs to be returned to ar. Hopefully soon can get either bill or peter over the house to relisten and re tweak with fresh ears. Covid thing has been travel issue for company
Ah that is a pain, so can you not listen to the system?
No small job
Hopefully you don't have underfloor heating to contend with?
Reactions: Hedgedrew66
This week i get recalibrated opus interconnect back and we will be burying cable in sleeve under floor and have the the room swept by audio engineers for sound waves etc.
Congrats! Beautiful. Make sure you have super-wide conduit if you have not already, and ideally very smooth internal sides (not conduit tubes which 'accordian'...any slight ridges can make it tougher to pull the cables through if you are turning bends, twists or turns under the floor.) And the width allows you to run more cable through (or thicker cable) if you upgrade in the future.
We did underfloor conduit which is great so there are no visible cables (unfortunately other than the Opus network box which I wish we had put under the floor as well).
Yes. Nice smooth pipe. Lol. !! All good with a pull. !!
