Ah, right so dynamic test signals might trigger issues & reveal more than periodic ones, right? What test signals are used in the measurements you put so much faith in?
Ah well, that's where you find yourself when you don't trust your ears - in the land of flawed measurements with no answers!
Why don't you try living with uncertainty - you do it all the time in the rest of your life?
Tim,
You already asked it and I have already answered. No need to repeat.
.... I could conceive of a situation where a DAC performed well in tests, but certain signals caused instability due to inadequate power supply bypassing of the output buffer or something, and the test didn't happen to trigger the problem. .......
I was allowing you the small possibility that a DAC could measure well in certain tests due to good fortune, yet badly at a different temperature, say, due to poor implementation. I am trying to pre-empt the nit picking but failing! If you have some examples of where measurements fail fundamentally could you volunteer that information?
No need - example already given THD 0.0015% & sound was "hard & bright". Modifications removed this issue.
I've already given you a real-world example which you reject.
Your logic really is flawed - you will accept that a battery of tests are needed to characterise an amplifier's transfer function but reduce this to only two for a DAC's transfer function. Can you please explain your logic?
Your second quoted post trying to re-frame your first quote, really doesn't wash, I'm afraid.
You mention signals in the first quote which I took to mean that you might be aware of the difference between dynamic & periodic test signals & the fact that certain signals might reveal performance issues in a device that could be invisible otherwise, hence my post along these lines but I see that it's a waste of time.
Yes. If I am convinced by the science that says no one can prevent themselves from being influenced by extraneous factors in sighted tests, then I 'know' that I cannot audition DACs meaningfully without a blind test. This just isn't going to happen for the reasons discussed. At the same time, if I understand something about the design of various DACs, then I can make an assessment of the meaningfulness of measurements of those DACs. For example, while I may doubt that THD and IMD measurements are a complete description of an amplifier's performance, maybe they are for DACs. If all DACs boast very, very good performance figures in real world tests, then maybe I can eliminate them from my enquiries - they're all going to sound exactly the same.
The clever part of a DAC is in the silicon chip inside the tiny plastic $10 package at the heart of the 100kg machined Tungsten enclosure. If I can reasonably establish that the enclosure, power supply etc. are ridiculous affectations then I can settle on a much cheaper DAC and spend the money on better speakers.
In summary: there is no way that I am ever going to be able to audition any equipment blind, nor would I want to. So I am looking for any short cuts that can cut out areas of wasted effort/money/time. Studying measurements and design is one way to do that.
I didn't say that every DAC could be perfectly described with two measurements (I'm taking it as a given that SNR and FR are very good* too), but that by studying its design one could maybe get a feel of how much trust to place in those measurements. If the internal workings of the DAC are understandable, almost mathematical, perhaps, and its load is easy and predictable, then maybe one can determine that there is no reason to believe that it cannot be adequately described by those tests. The measurements are merely confirming the theory and supporting the implicit assumption that the manufacturer has followed the data sheet.
Amplifiers are another kettle of fish. The speaker load will be unique for each type of speaker, parameters will change as temperature varies. A test that shows perfect stability into a resistor or a dummy load may not reflect reality. I accept this, and would seek reassurance that the manufacturer knows what they are talking about. I have read a lot about Quad, and I tend to trust their judgement on these matters, for example.
Again, your second quoted post trying to reframe your first quote, doesn't wash, I'm afraid. That's exactly what you said.
If you constantly try to change what you said theres no point in discussion with you!
Tim, it's already posted a long while back - it's John Westlake's experience, not mine. Some people called him "some dude", perhaps they should look up the guys work for a frame of reference.So you discovered the source of the hard and bright and managed to fix it. What was the problem?
And just so I have a frame of reference, do you consider the Benchmark DAC "hard and bright?"
Tim
Yes, the get-out, politicians words, I did not miss.Those two quotes are perfectly compatible with each other! There are no certainties, hence my use of the words "if", "may" and "maybe". Even your highlighting failed to miss one "may" and a "maybe".
But you revealed your hand by then going on to argue for the case that DACs really don't matter as they sound "pretty much" the same.
I refuse to debate with politicians - they tend not to be interested in the truth!
a 500W power supply with 1F of capacitance is not going to make any difference at all to the sound, or the measurements.
If you want high-end performance you need a high-end power supply.
Inside the NWD is a huge transformer, coupled to many thousands of microfarads of capacitance, Linear Technologies regulators and high speed, low noise diodes. We have taken every effort to make the NWD as good as it gets through careful power supply design.
It is here, in this all important power supply region, where voices and instruments take on what is known as proper “bloom” and give us the illusion of being right in the room with us. The last thing you want is an anemic sounding musical presentation – but with the right power supply, you get the fulness of the music in all its glory.
J_J,
I have no reason to doubt of it. Are the conditions, data and results available to scrutiny of WBF members?
"Well-run DBT" is such a misused term that unless we are given good descriptive examples to debate we will go on debating futility forever.
First, I have participated in rather too many well-run DBT's.
Your second question is out of context. Use what you want when you buy something. That's not science.
As to your dishonest straw man, based on an appeal to emotion, an appeal to ignorance (disguised), appeal to facts not in evidence, and then another straw man or three, coupled with an extraction from contect and a confutation of scientific concerns with purchasing concerns (the last of which some so-called objectivists are also guilty of, but not all, and by implying universality, you widen your attack as a further emotional appeal that is both abusive and malicious), well, I think that's just a start on the fallacious nature of your insults.
DBT's are for science.
It's that simple.
When you claim an effect actually exists, you are making a testable claim, and that puts your claim in the realm of science.
If you say "I like this", that's all there is to it. You like it. Fine. Preference is inviolate.
And I think we'd like to see the DBT that backs up your so-called "real-world" example.
You've entered the realm of science, and now there needs to be some rigor here.
