You have a good ear. Earlier today I had a power outage right when I was going to make the non CC video. It is very possible that the volume is not matched exactly. The volume level was set at 9:10 as this tape is very "hot"The f
The first video seems brighter and has more dynamics. The soundstage seems clearer. Sound is more coherence and even in all regions.
It seems both video is playing at different volumes but the difference is distinguished.
Maybe the phone is lying to us.
The music is subject to copyright law and not published. So the video is now private. The videos were a experiment for me and I shared it for a time.How you do that?
* Roger, what did you do?
Bob,Oh I see, the music ...
Can you redo the test but this time with Led Zeppelin? ...Something everyone use on YouTube.
Let me see if I can find my Sarah Vaughn 2 track since the CC is setup on my RTRBob,
I have the CD only. Stairway to heaven should be fine. Tomorrow probably
Hi David, thank you for your reply. We are not looking for alternative materials, but I am interested in your experiences. Let me take the opportunity to explain why. Most of what I'm about to write is known to you, so do not consider this to be directly addressed to you, it may however be interesting to others.
We started using panzerholz about 2.5 years ago to solve address an issue we found when we started modifying the Table Stable active platforms. The issue was these active platforms "isolate" up to 200Hz, in order to do that the feedback circuit measures up to 2000Hz to account for harmonics, as a 200Hz resonance will have harmonics at 400Hz, 600Hz, 800Hz etc. They are fitted with an aluminium top platter sandwiched to a steel frame which causes no issues below 2000Hz. However Aluminium is very resonant above 2000Hz. It's resonance spectrum does not complement any type of musical instrument behaviour so we consider this an undesirable trait.
For painting a complete picture, material resonant behaviour is what makes musical instruments function. In stringed instrument, like a Violin or a guitar, the sound radiation source is mainly a top plate, in pianos it's a soundboard. The strings excite the natural resonances of the top plate/soundboard which are usually made out of wood. The wood provides a dual function, amplification, as it will amplify at its resonance frequencies, and damping, as it will damp some the high frequency resonance of the strings. Spruce is most often used as a soundboard material as it has low density and low internal friction (damping). Maple has higher density and higher internal friction, usually only used to construct the casing. Engineered woods can have even higher density and internal friction. Interestingly one of the applications of Panzerholz is to serve as the frame on which soundboards can be mounted in grand pianos.
So we tried a lot of materials, a whole range of wood types, the highest damping woods however came with strong resonance modes in the midrange, both upsetting the Table Stable feedback circuitry and obviously colouring the sound. Bamboo plywood was the best compromise between low midrange colouration and damping aluminium resonance as far as natural wood goes. Composite Bamboo did a bit better, but still not well enough. Then we tried a whole range of high damping composite materials, stones and artificial stones with varying results and finally ended up trying Panzerholz which did the best job by far. We ended up with replacing the stock 6mm aluminium top cover with a 10mm one and sandwiching it with 10mm Panzerholz.
Later on we discovered placing the Table Stable on top of a 40mm board of Panzerholz and adding another on top improved performance even more. Then we got enquiries from customers who wanted to try Panzerholz boards stand alone, so we shipped a bunch out, received feedback claiming good potential, incredible bass, significant increases in clarity but a bit of a "hard quality" to the upper midrange/lower highs, some upper midrange smearing and we should do something with it. So we did, we discovered there where some small modes in the range centered around 3K, we moved those to over 20K by machining all sorts of patterns into the Panzerholz, ended up with the current design as it has no repeatable distances across the board, think diffusion without repeating distances for a sound room. This took care of the upper midrange modes and the associated smearing. Then we had to address the hard quality to the upper midrange/lower highs.This had us baffled for a long time until a conversation with Table Stable introduced the concept of micro oscillations to us. Everything oscillates. Even 2 surfaces, bolted rigidly together, are subject to micro oscillations between them. This is for example what can loosen bolts over time. Even large masses are subject to this. You can move very heavy objects with minimal force if the surface beneath it vibrates. Another example, Tiny Multi Layer Ceramic Capacitors can vibrate significantly when exposed to AC voltages, they can even break off the PCB over time, as they actually cause PCBs to slightly warp under the vibrations they emit. Guess why nobody likes to use those in Hi-Fi.
The upper midrange/lower highs harshness was the whole board, with appliance on top, literally bouncing on the floor. An easy way out is using compliant footers, like rubber. But these have a side effect. They create a spring-mass system, the frequency response of this is the lower range passes through, up till the resonance frequency of the system where it amplifies (!), after which it starts damping. The amount of damping defines the amplitude of the resonance peak. This is NOT a neutral Frequency response:
If the compliant medium (rubber) is stiff, this can be way up the frequency range, up into the midrange for example. So we came up with the not rigidly mounted footer system damped by foam. Micro oscillations are damped and it has no resonance peak.
Now I've been writing the foams affect the high frequency damping. That is actually a gross oversimplification, if you remove any of those, you start introducing a degree of micro oscillations. That sounds wrong, but it isn't really, as it is just a way of voicing. Ultimately voicing is all about managing resonances. You introduce them in all kinds of flavours, like seasoning in cooking, a bit of spruce here, a little bit of maple there, maybe add a touch of copper, or maybe your dish needs a hint of silver?
Bottom line, the Daiza is virtually neutral. But do you want it to be neutral? Or do you want to use it to add some flavour?
David I wanted to ask you this included in my previous post, but was cut off by a customer walking in. Just to be clear, I love tweaking and voicing, and from time to time I introduce colouration in my system on purpose. Its very easy to do, although I prefer to introduce it into my room acoustics rather then my equipment. For example from time to time I tune the materials used on the first reflection points on the sidewalls with various flavours of wood. I have included frequency response measurements of various types of wood below. This is the material response from being subjected to a frequency sweep from 100 to 10.000Hz from a speaker mounted at a 2" distance from the board.
Sp1 and Sp2 are 2 variants of Sitka Spruce, He is Hemlock, Map is Maple, Mah is Mahogany, Mat is Matoa, Acryl is Acrylic Resin.
Now this is all obvious, when hit by soundwaves the reflection will either not change, be amplified, or damped causing the sound Frequency Response to be modified.
Now suppose we use it as a material for a tonearm or a cartridge, or even turntable material, it would be very feasible it will modulate the cartridge operation by translating its vibration into an electrical signal . Would you agree to that?
Next, how do you propose it does this when used as a platform underneath, say a preamplifier made out of a metal chassis with circuit boards? How does it modulate the sound? And why would you prefer to use Maple or another hardwood for that with very obvious resonance modes? (colouration)? Is this, in your opinion, a way to add natural material resonance to the sound? Or are you doing it to introduce a degree of isolation by means of a deliberate surface to surface impedance mismatch for which there are obvious better choices?
I’m on the record here with my views on the Stable Table and it’s use under turntables.
david
“how do you propose it does this when used under equipment with metal chassis and circuit boards? How does it modulate the sound?”
Spirit,
Just found this from the legendary Atmasphere himself when someone was asking about SRA:
atmasphere
12-22-2010 4:11pm
It is impossible to mechanically over-damp audio equipment (I am not talking about electrical damping).
If you are of the opinion that this is not the case, then its likely that you are used to dealing with synergistic effects which is usually not a good way to set up a system.
Now it is possible to put so much damping product on a tube that you can damage the tube by overheating it, but this is an issue of heat rather than damping.
Let's say you are compensating for a brightness by using dull equipment elsewhere. The result may be an even tonality, but one that is lacking transparency and detail. You are much better off if the equipment stands on its own merits and lacks coloration on its own.
This is why a good stand for amplifiers or for the front end of the system is a good idea- the less vibration you have, the greater the ease that the gear can realize its musical potential."
2- I don’t build and sell wood platforms to change the sonic balance of equipment so I should ask you that same question, “how do you propose it does this when used under equipment with metal chassis and circuit boards? How does it modulate the sound?”
It doesn't, that is the point I'm trying to make. You are claiming it "kills" the sound, so I'm interested in how you think it can do that.
What it does do, measurably, and you can even confirm this by a simple "knock" test, is reduce the time a metal chassis rings after being exited. It also decreases transformer hum, reduces capacitor microphonic distortion and lowers XO phase noise sensitivity to vibration.
Hi David,
I'm completely aware of your aversion to this technology. Yet there are several threads, I'm counting 8 in the "Vibration Control Forum", discussing the ins and outs of this, including applications for usage with turntables. So I'm not going to discuss this again.
(...) Please explain why when you transfer a digital file from one box to another over a 10cm connector the reproduced sound is affected and even drastically at times will change again using a different set of connectors and conductor yet when you open the transferred files they’re identical to the original.
