The last few plinths I've made are more like layer cakes - the recipe. For Garrard's and other idlers, I'm using 2 inch of either hard maple or cherry layers alternating with panzerholz and then 2-4 inches of bamboo for the bottom layer. To my ears, this combination is super effective at quieting the idlers mechanical noise but also keeping the liveliness and dynamics of those decks in good order. My latest experiments adding bamboo has really been a nice icing on my layer cake. It seems to augment the damping of panzer and also the liveliness of hardwood - go figure... For the direct drive decks that I've worked with, I've used layers of 6061 aluminum.
I "wrap" the layer cake (inner core) with 2-4 inches of solid hardwood and use decorative woods mitered into the corners; you can see the latest one I did in purple hart wood and maple....
Excellent craftmanship! Beautiful work. Stacking materials of varying density is interesting as it increases the acoustical impedance. Soundwaves transport badly between 2 materials with different density. It is the same mechanism as sound moving through air in your listening room reflecting off walls, the acoustic impedance mismatch between Panzerholz and Bamboo is larger then that between Panzerholz and Cherry, so more energy will reflect on the junction between Panzerholz and Bamboo. Where this becomes a very complex model is that these materials have different internal damping and modes. And then there's the question of if you want to reflect and/or damp energy, or if you want to "transport" it as efficiently as possible. And in case of the latter, where are you "transporting" it to, and what are you getting back in return as that is a 2 way street. So the result here is going to be variable depending on the properties of your rack, and your floor. And in the end you will just have to listen, if for private use that's all it takes, if you're a manufacturer it needs to perform in a wide range of different scenarios. As a manufacturer I can 99% guarantee good performance from using panzerholz platforms with equipment made out of aluminium, which is wat virtually all digital gear is made out of and also the bulk of solid state amplifiers / pre amplifiers. But for turntables, tube amplifiers, and loudspeakers, often constructed from different materials, all bets are off and it becomes a guessing game.
