A good debate is valued, and enjoyable. Your reply is so full of anger, seasoned with a tasty morsel of hypocrisy (“appeal to ridule,” then off you go, ridiculing away), that it will fail to inspire anything even close to legitimate disagreement. It just makes you look like a petulant child, who just doesn’t understand why genius isn’t being acknowledged.
You may have gone to “university” as your post implies, and maybe even a good one, but if you studied anything at all about randomized testing, bias and why all RCTs produce bias, then you should consider suing your university for malpractice. I’d suggest developing some thicker skin so you can actually defend your position, instead of resorting to the very ridicule of which you accuse David.
And do try to keep gross political generalizations out of audio debate: i disagree with you, and I don’t fit into any of that political word salad you tossed.
I agree about political generalisations, I took it off after reading it, apparently too late. My apologies to all.
In regards to RCT producing bias, why would you say that? A RCT, if done correctly, is the most reliable study one can do.
My suggestion that expert opinion, being the lowest strength of evidence in the hierarchy, should be scraped and instead replaced by RCT.
ddk replies that he believes I was addressing him. No, I was thinking of an entry by PeterA actually, but no matter, the point is the same.
I mentioned collecting a group of paired systems, the pair identical except for the substitution of Panzerholz in one (plinth, tonearm, rack bottom, etc.), but each pair different to the next pair so as to prevent skewing the results (by one outlier). The point is finding statistical significance. I did not say anything about who would choose the equipment or what equipment would make up the various pairings, only that they be identical within but different to each other.
ddk said: LOL, for a "successful" study and "meaningful" results the listeners can not be randomly chosen from society to give their opinion as to which (A or B) sounds better to them, but must be made up of "knowledgable, experienced, competent panelists", (such would be totally biased).
The point is not to find experts who agree with you to listen and then say which equipment sounds the way they like, but to put out two unknown variables to randomly-selected naive listeners and ask them to tell you which they prefer the sound of. If there is no statistical difference, then that is the answer, end of argument. If plain wood better than Panzerholz, the same, etc.
Then ddk starts describing some imagined scenario wherein the equipment used for evaluating is just one system (not several matched pairs), that is poorly constructed.
ddk writes: "Conversely, what if this test system is one owned and setup by an incompetent clueless fool who buys mediocre sounding gear as long as they're expensive and then starts piling up tweak after ridiculous tweak reaffirming his ignorance declaring the latest purchase or tweak as the greatest ever until the next idiocy? Worse still he's among your panelists!"
WTF ddk? You are so hell-bent on arguing your point that you create a ridiculous scenario that bears no resemblance to the conditions of the study I proposed for the simple purpose of ridicule (fallacy of logic, appeal to ridicule) (had there been any part of it which resembled the conditions of the study I proposed then you could have moved up the ladder to the fallacy of logic called "straw man" wherein the opponent in a debate simplifies the proposal of his opponent to such a degree that it can be easily blown over, hence "straw man").
But your scenario has nothing in it that resembles in anyway what I was suggesting for a study. It is just a fiction you threw out there. But why would you choose that particular description for your imaginary test equipment/panelist, unless you looked at my equipment listed under my posting and, finding it expensive, decided to covertly deride me personally as that "incompetent clueless fool who buys mediocre sounding gear as long as they're expensive" in your posting. Is that it?
Had you not read my entry carefully and were just being stupid, or were you being nasty?
