correct. With the emphasis on WHAT THEY HEARD.
I'll just say that again.
What they heard.
yes...
What they heard.
An just in case you missed it...
What they heard.
And one more time for the slower people.
What they heard.
And when objectivists actually do that consistently then I think you would find a lot of animosity might dissipate.
For those living under a rock this last fortnight, I am of course referring to the massive Entreq war in the general forum where not one single detractor of the product had actually heard it.
So practice what you preach please and you guys might actually garner some respect.
Then you have not understood what has been said in that thread.
You do not need to have heard the device to have a technical opinion on it.
Years of experience (not listening to noise problems in instrumentation) allows me to know that if you have a noise problem it can be solved without the need for expensive esoteric boxes full of magic crystals.
The point made in the thread was that the entreq has no technical merit beyond what can be achieved with some ordinary cable and a connector block.
Also that if you have a noise problem, find out what the fundamental issue is and solve that first.
Also, most who implement these boxes have no idea even if they actually have a noise problem, and could even be introducing one with its use.
Oh yes, also that the initial measurements showed there was a big problem with mains harmonics in the system. The entreq reduced the mains harmonics but INCREASED the HF noise. Once the "problem" cable was replaced the entreq made almost no difference to the still unusually high level of mains harmonics.
So that demonstrates the reason why you should fix the problem first before looking to this tweak as a solution. It also demonstrated there was still a bit of a problem to solve.
