Myles, did he ever answer your question?
I'm not Frantz, but here you go...
...at $1895 it would be pretty grossly over-priced for a chip and enough juice to bring its analog output up to line level, but the addition of an excellent pre amp and headphone amp bring it pretty close to worth the money.
HK 990 integrated. $2500. A little pricey for just 150 watts a channel, but you get a really good preamp thrown in. SOTA? By any measure that does not include personal opinion, it holds its own with anything in its range (power, not price) and out-performs MANY high-end amps at many multiples of its price. And yes, it doubles output as you drop ohms. Grunt. Lots of grunt. That's the technical term.
The Revel Salon. It begs the question "what is SOTA?" If it's anyone's opinion, I suppose all bets are off and there's really nothing left to discuss on discussion forums. If it is any kind of measurable, repeatable performance, these are not only hard to beat (when properly amplified) in the passive realm, they kick the soft, mushy, poetic butts of most statement speakers. Hell, they are more accurate 30 degrees off axis than a lot of SOTA flagship speakers are in the sweet spot. Got a listening room the size of a showcase club and want to create hyper-loudness? Buy two pair, and two of the HK 990s. They'll still be a bargain in the company of flagship "high-end" speakers.
And of course all of the above is doing it the hard way. If we could just get past our box and wire fetish and go active...
Tim
ON EDIT: What's Best? Plug a computer full of lossless files into the $24,500 system above, and what stands between you and "What's Best" will be someone else's opinion only. It certainly won't be facts or specs or anything quantifiable. And the truth is, the above system is over-engineered and the Salons are over-sized for most domestic listening rooms, so most of us could probably match its performance for a lot less, again, by any objective criteria. So what are we about here? What's best? Or what's expensive?
