No, never tube rolled my amps. In almost 20 years I went from the stock Riccardo Kron 2A3's to Shuguang to Psvane to Psvane Acme's. Thanks, LarryLarry did you ever try the eml mesh 2A3 tubes ?
If by “complexity” you mean being able to separate out individual instruments from a complex mix (e.g. orchestral music), I definitely agree with you. I think the imaging is better, more stable, too.I thought the TJ were quite poor compared to EML, KR, Elrog, etc when it came to extension and complexity.
I suggest you try Elrog and KR, on amps I prefer Elrog. They are more neutral, less warm than the typical 300b
Ked, do you have any experience with the Elrog 845’s? I wonder if your sentiments generalize over the entire range of tubes they offer..... they are pricey beasts for sure.
I would say give it about a week or two before getting critical about what you're hearing. IMO if it's still lacking what you need at that point, rolling the 6SN7 would be the way to go to inject what you feel is missing. There are many NOS variants that would give you what you seek. For example, a pair of National Union Black Glass might do the trick.
Funny thing, several days ago when I switched from the stock Shuguang WE6SN7 to the Psvane CV181-T mkII with the stock JJ Full Music 300b, I was getting that more full body mid-bass and bass. Once I switched the JJ Full Music 300b to the ACME 300b, that mid-bass and bass got a bit thin, although the bass is super responsive and tight. The mid and up do sound great on the ACME 300b. It's still smooth like the previous CV181+Full Music 300b, but has better extension and way better instrumental separation and staging.
I also have a Schiit Loki coming in a few days, so hopefully I can add some of that body back. Hopefully with more burning in, the bass will also open up more than now.
@JoeyGun If you’re looking for instant information and gratification, I’m afraid you will find yourself none the wiser, but definitely poorer and frustrated. I’ve found new tubes, like most everything else, need 300-400 hours to find themselves. What I do now is pull the other tubes and leave the unit on most of the time — a bit of downtime helps too — until I need to run the unit. That's recently been the case with both an RK and Psvane WE recti replica in the Lampi TRP, and NOS Brimar 13d5s in a preamp.
Just wanted to share my experience with Psvane, not very impressed with their customer service and product quality.
I have been using the ACME 845 for 4 months. One of the tubes started to develop problems over time. After I switched the amp off, one of the tubes remained bright for almost 14s while the other didn't have this issue. And the side where the tube remained bright, the speaker would emit some noise before the tube finally cools down. The seller insists that the tube is fine and asked me to continue to use it.
However, it got worse. The side with that problematic tube started to have a cracking sound every other second so I quickly switched the amp off.
I should have heeded the warnings at the beginning of this thread. I thought I wouldn't be so unlucky but I should have learnt not to take chances for such an expensive tube. I asked the shop to send me a replacement pair but the seller on taobao insists that i send the tubes back so that they can send to the factory for testing; they will replace if they test that there is an issue. So even if your tube blows up, they will insist you send it back to the factory. Will see how it goes and if they eventually replace it for me but it will be a long wait....
So yes, you might want to consider other more reliable tubes if you don't want to go through the hassle of replacement and dealing with Psvane on the warranty. It's a pity that Psvane didn't do any better, I was really liking the sound of the ACME 845.
Here’s a tip for the 6sl7 - Tungsol made a low noise military version called the 6su7. Is a similar build to their much revered round plate 6sn7 and on a similar performance level. Very rare though.
