Psvane Acme Series (new flagship series)
chaccone
8
8
133
Just wanted to share my experience with Psvane, not very impressed with their customer service and product quality.
I have been using the ACME 845 for 4 months. One of the tubes started to develop problems over time. After I switched the amp off, one of the tubes remained bright for almost 14s while the other didn't have this issue. And the side where the tube remained bright, the speaker would emit some noise before the tube finally cools down. The seller insists that the tube is fine and asked me to continue to use it.
However, it got worse. The side with that problematic tube started to have a cracking sound every other second so I quickly switched the amp off.
I should have heeded the warnings at the beginning of this thread. I thought I wouldn't be so unlucky but I should have learnt not to take chances for such an expensive tube. I asked the shop to send me a replacement pair but the seller on taobao insists that i send the tubes back so that they can send to the factory for testing; they will replace if they test that there is an issue. So even if your tube blows up, they will insist you send it back to the factory. Will see how it goes and if they eventually replace it for me but it will be a long wait....
So yes, you might want to consider other more reliable tubes if you don't want to go through the hassle of replacement and dealing with Psvane on the warranty. It's a pity that Psvane didn't do any better, I was really liking the sound of the ACME 845.
christoph
4,674
4,071
825
Principality of Liechtenstein
Have you tried the seemingly faulty tube in the other channel of the amp?
Does the problem stay on the same channel (amp's fault) or does the problem wander to the other channel with the seemingly faulty tube (tube's fault)?
chaccone
8
8
133
I am using monoblocks. Yes the problem follows the tube when I switch the tube to the other monoblock so definitely it’s a problem with the tube.
christoph
4,674
4,071
825
So this is a definite sign that the tube is at fault.
Did you tell the dealer about the fact that the problem wanders with the tube?
christoph
4,674
4,071
825
PLGA
7
2
3
50
Thanks for the reply.
I have read in various forums that Robert is a seller known and appreciated not only in Singapore, but also in the United States and Australia.
I would like to buy the Line Magnetic LM-219IA from Robert. In Europe it is difficult to find and has a high cost.
Unfortunately i haven't experience of tube sound. Line Magnetic would be my first purchase.
I would like to know if Robert attaches the wiring diagram for any future technical interventions as documentation.
These are some improvements made by Robert on the LM-219IA and I think also on the 845 premium:
"The power section capacitors upgraded to Mundorf & Vishay capacitors with low noise rectifier. option of coupling capacitor includes Urushi capacitors, Mundorf SGO capacitors, Furutech Rohdium IEC inlets etc."
Could you tell me the price of the Telefunken that Robert gave you?
What would be a fair price for a matching pair?
Regards
Hello @faggella @wisnon and @Saleh84
I contacted Robert Lai by email to quote me the information and advice on how to internally mod my LM-508 with a local tech here as I live in Argentina and its impossible for me to send the amp to him.
Im willing to take the chance on changing the internal parts of the amp only if the upgrade in sound quality is "really" good, not marginal. Otherwise, upgrading valves becomes more reasonable and safer.
If any of you have done any mods with him, what mods in your amps have you done with Robert and how would you describe the upgrade in sound quality?
Any other who would like to share his experience on modifying any Line Magnetic amp?
Thank you!
faggella
16
1
8
55
Thank you!
HI
I purchased an integrated Line Magnetic LM-219IA Singapore version from Robert Lai.
So the amplifier came to me already modified.
I can't tell you what sonic improvements the changes made by Robert bring, you have to compare the standard version with the Singapore version. But buyers of the standard version are also happy with the sound of their amplifier.
I can tell you that the sound of my LM-219IA is very natural.
As Robert himself told me, the changes made concern:
Furutech AC inlet for pure clean power transmission
Gold plated 845 valve Socket only found in HiEnd tube amplifier
Mundorf / Vishay Capacitors
Lower noise floor improved power supply
Urushi / Mundorf Signal coupling capacitors
German low noise rectifier.
If you are not sure of the changes to make, I would limit myself to replacing the valves.
Regards
PLGA
7
2
3
50
HI
Regards
Thank you for the reply.
Yes, making any change in the amp will mean a lot of effort, not few money and considerable time and patience.
I would only think about it if I find at least a couple of LM amps owners who have successfully done it with great results.
Im very happy with the amp as it is right now and soon will get the ACME 805s, so Im not on a rush.
Reactions: faggella
wisnon
3,536
640
1,200
Thank you!
Sorry,
I use SS amps.
bonzo75
22,621
13,641
2,710
London
wisnon
3,536
640
1,200
LoL.
It means I cant answer his question on feedback of Acme tubes in tube amps.
No, I am NOT sorry about using small SS monoblocs that can deliver 1300wps into 0.5ohms and do so in a stable fashion. I thus get extreme control of my woofers and nigh unlimited dynamics.
JoeyGun
39
23
75
42
Where do you guys find to be the best place to buy the ACME 300b in the US? I live in Los Angeles, and of course, in case things go wrong with the tubes and I have to use warranty, I'd like to have not deal with shipping far far away.
Dthagerty@aol.com
81
60
208
Solana Beach, CA
I've purchased Psvane tubes from Grant Fidelity, including having to return some. Good to work with. I would have no hesitation to buy from them again.
JoeyGun
39
23
75
42
Sadly, his page doesn't seem to have the ACME's in stock =(
dcc
660
1,302
1,230
Continental Europe -
I got this pair for the amp of my secondary system. I will plug them next weekend:
For the 300B drivers, I opted for the the KR Audio RK Limited Edition:
christoph
4,674
4,071
825
Wow, what a nice tube complement.
I wonder how much better those sound than the stock tubes?
astrotoy
1,551
1,020
1,715
SF Bay Area
Grant passed away about a decade ago. His partner Rachel has been running the company. Excellent service over the years with my Shuguang and then Psvane Treasures 2A3 and my Psvane Acme 2A3s. No problems. My understanding is that Grant has all their tubes pretested. You can contact Rachel for more information. BTW, Psvane is pronounced Pavane (the s was a typo - the printers thought the script "a" was an "s").
I met Ian Grant and Rachel at the first DaGogo show in Oakland around 2010. They were very nice and bringing into North America (Canada) some of the top high end Chinese tube equipment and tubes. I switched from Kron to Shuguang tubes and then to Psvane. Now I use both Kron and Psvane Acme tubes with excellent results.
Larry
PLGA
7
2
3
50
Hi guys
I've just ordered the 805 ACMEs to the dealer who sold me the LM-508IA and some other gear, china-hifi-audio.com
Due to shippment and customs delay, it will take about two months to get here. I will post my impressions latter on.
Reactions: faggella
