QSA : My take on their expensive products
QSA - fuses, jitter plugs, outlet/receptacles, switches, routers, Lanedri cabling - now to figure the best combo that will fit within my budget.
This is my dilemma as well. I was thinking of starting with a receptacle but now thinking of a jitter plug on my Ansuz conditioner so everything benefits.
I went Jitter IEC inlet plug into the Torus which powers the entire system. Quite a nice improvement.
Reactions: audio42
Me too, after some fuses, installed a jitter plug on the wall outlet with good results from both.
The latest upgrade was the dedicated power spur and the Redblack
wall outlet .
As I have commented earlier that has effected a major improvement in sound quality and has been the most cost effective upgrade ever.
Acccordingly IMHO ,my advice to anyone contemplating going down the QSA road would be to start with a dedicated power spur and the best QSA wall outlet you can afford
Reactions: audio42
…Acccordingly IMHO ,my advice to anyone contemplating going down the QSA road would be to start with a dedicated power spur and the best QSA wall outlet you can afford….
Thanks, Barry. Been wondering if would do many item less expensive vs few items but higher quality. So outlet for sure. I’ll later try jitter plug, power and speaker cables- 30 day money back guarantee seems foolproof….on emptying my wallet. Step at a time. Fuses, no - couldn’t take the heartbreak if one blows
What’s “power spur”?
Thanks K
My QSA fuses have been fine for the last couple of years
Power spur. Dedicated power line from the house mains supply to the new QSA wall outlet. Completely bypasses all the other mains connections and outlets so stops any EMI generated by other appliances reaching the audio system.
There was a very good article in a recent edition of HiFi Plus on this upgrade. More details of my install in my earlier posts.
I wouldn't recommend the QSA entry level products. Mid range upwards IME are much better buys
Reactions: KPC and audio42
Does QSA make 6x32mm 10Amp fuse i couldn't find them ?
Thanks.
