Rear Wall advice for small room, but not what you think
rhyno
75
31
1,573
aloha guys
small room here (15'*11'*8'), with Magico S3s set up on long wall. Maybe 8' from front baffle to ear, and frankly i've got a killer stage and excellent measured response (thats what ten 16" ASC tube traps, three 6" thick bass panels and four 4" thick bass panels will do--they clean up the bass). seat is unfortunately < 2' from rear wall. but by and large, i'm very happy with the sound, but i'm an audiophile always looking for better sound...i'm not griping about bass or tone or staging. my issue is with the completely dead nature of the room's rear wall (where six of the aforementioned bass panels are stacked). i'm absorbing everything short of oxygen, and it makes the room a bit too dead behind me--no reverberation or air. removing the panel behind me causes some nasty colorations, so thats not the way to go.
any products i should consider? was thinking of trying diffusion but A) i gather diffusers need more than 2' between product and ear, and B) when i tried RPG skylines there i didn't like them (admittedly a cheap foam product has a coloration, which is what i likely heard).
mahalo
rhyno
aloha guys
mahalo
rhyno
Keep the acoustic treatment at the reflection points on the rear wall fully absorptive, set up the rest of the traps on the rear wall to reflect higher frequencies. You'll either need to modify them or swap them out to do this, unless they are tubetraps, in which case you can just rotate them so the reflective side points into the room.
2' is too close for any phase based diffuser like a Skyline. Amplitude based like BAD or a slat diffuser is fine.
Absorption is a delicate balance...it's very easy to over do it and kill room ambience and the sound. I use full absorption traps on my rear wall behind my seat as Nyal mentions and sit about 3-3.5 feet from that wall. I have quite a few traps in storage having bought too many from poor advice.
Use this product you can find at most places that do digital printing and signage on your bass traps
Its called contravision .. its reflective to a fair amountof HF and it allows absorption and bass passes thru
Its printable so you can make it look nice with graphics etc
google "contravision"
