new guy in town.
I am trying out a new RCM. the KL Audio Ultrasonic Record Cleaner.
it's a one-button machine like the Audio Desk. actually, it's a 'no' button machine. you place the Lp in the slot and it automatically cleans and dries it. you can walk away and come back later. it 'beeps' when it's done. you can vary the minutes of cleaning and drying. it uses about 1/2 gallon of distilled water per 50-100 Lps depending. I used a funnel to pour in the water, there is a window on the front that shows 'min' and max' for water level as you fill it. very easy to use and intuitive for dummies like me.
it only uses distilled water and ultrasonic cleaning, there is no cleaning fluid of any kind and no brushes. nothing touches the Lp but water and the ultrasonic bubble action.
it uses a 200 watt ultrasonic unit, my understanding is that the Audio Desk uses approximately a 10 watt ultrasonic unit. so the KL Audio has 20x the ultrasonic cleaning action of the Audio Desk.
how well does it work? so far, I've only cleaned a couple of Lps; but they came out 100% dry and clean and sound wonderful. maybe a touch more pristine sounding than the Audio Desk, but it's too soon to draw any conclusions. there are fewer moving parts than the Audio Desk since it does not need to spin the brushes, but it still spins the Lp. it's built really well, and my understanding is that it's stainless steel inside for durability.
it's relatively quiet but it does emit a raspy sort of noise (like 'pink' noise) during the ultrasonic cycle.....so you might not want it in the same room as you are listening in. in my situation it's with the other RCM's right outside my room, and I don't hear it in my room with the door closed and the music playing, but I did hear the 'beep' when it was done.
works for me!
i'm into easy. this is easy.
here it is next to the current best RCM's on the market....the Audio Desk and the Loricraft PRC4 Delux. we will see how it does.
View attachment 10719View attachment 10720View attachment 10721
