I still can hear a basically untreated bare surface large room...
Needs randomly strewn planks![]()
I called for my wife Siri to listen to the vids and after 10 seconds she said the room is underdamped
and I totally agree....sounds like you play in a hangar
Eva Cassidy "Fields of Gold"
from which album was this?
The Jadis is quite a bit softer and warmer sounding. Is this still with KT90s or do you have EL34s in there now? If not, then EL34s will likely push it even further in the warmer/softer direction...particularly something like Mullards. KT90s are not really known for being soft and cuddly tubes.
I think it does trade off a bit of resolution for a more "pleasing" listen...not that that is necessarily a bad thing. I would actually expect a good high powered SET to be less "romantic" than the Jadis based on what I am hearing here.
in my headset it sounds as if you have too long reverb time in the room.....kind of hollow echo effect
Personally I don’t think Al would have heard this in person either. Maybe it’s him and not the videos?Brad and Kedar are reporting correctly what I hear as the differences in the room between the two playbacks:
did you ever measure reverb time at different frequencies
otherwise smooth and clean will good tonal balance
The interesting question for me is would moving to JA200s Mk. II increase or decrease the softening? Bring back some of the resolution and information? Reduce the softening and richness? Increase transparency or increase fuzziness?
Hi Ron,I am happy with the crudely measured RT in the room.
Brad: "The Jadis is quite a bit softer and warmer sounding." I think it does trade off a bit of resolution for a more "pleasing" listen
Kedar: "The video on top sounds harder, clearer, and I can hear more how she is singing with more fluctuation in the voice.
"The video at the bottom not have the hardness and no stand out thing, balanced, but keeping out info"
These comments track the differences I am hearing in the room between the amplifiers.
