I thought you were after a SET/ PSET amplifier.
This is my last audio bucket list item. I want to use the JA100 experience to attempt to triangulate on the power level (52 watts (Absolare SET), 120 watts (MastersounD PSET), 160 watts (NAT Magma Eimac) and circuit type (SET/PSET) and tube type (845, 833, 450TH) which might yield the highest probability of success.
I am not going to be able to close this exploration without trying high power SET or PSET at some point.
Are you thinking higher powered Jadis with EL34 is a substitute that will drive your big speakers?
The JA100 with KT90s at about 80 watts definitely is not an obvious failure. This realization alone has been very educational and enlightening. There now is no doubt to me that, as almost everybody reports, the Jadis transformers belie the amps' wattage ratings. The KT90s already are adding weight from the lower midrange on down. Maybe EL34s in Jadis might be too much of a good thing?
So, yes, I immediately wonder whether JA200 Mk. II with EL34s might preserve most of the lower midrange on down weight of the JA100, and recapture some resolution and transparency, without losing the midrange "magic." (A lot of
ifs there!) Whether that would get me all the way back to the power and control and dynamics and soundstage solidity of the Siegfried II is another big question.
Gideon Schwartz of AudioArts in Manhattan visited me today. He is a long-time Jadis (and FM Acoustics and Goldmund and Zellaton dealer. Gideon is very nice and extremely knowledgeable! He advised me that the JA200 Mk. II would be a "lateral move," meaning, I think, that he does not think I would pick up enough in the way of dynamics to justify the JA200 Mk. II. He recommended his Goldmund solid-state.
But if I insisted on staying with Jadis Gideon recommended a move all the way up to JA500 Mk. II. However JA500 Mk. II is Class AB. If I were going to go 12 tubes per side Class AB I would just stay with the Siegfried IIs.
On the other hand the 300 watt JA500 Mk. IIs might be an excellent compromise if they provide most of the dynamics and soundstage solidity of the Siegfried IIs while adding a good dollop of Jadis midrange and, hopefully,
weight from the lower midrange on down (which is what I am hearing loudly and clearly from the JA100s).
