I think he coded Al bot for thisEither Ron thinks the videos can be used to promote discussion on how the two videos sound
Brad and Kedar are reporting correctly what I hear as the differences in the room between the two playbacks:
These comments track the differences I am hearing in the room between the amplifiers.
Needs remastering the system
I agree with Brad and Ked’s observations but wanted to add more. To me the videos sound very different especially tone of the guitar. Dynamics and immediacy are also quite different. If the acoustic panels were consistent between the two videos, we could confirm differences are between the amplifiers.
What I find interesting is that people‘s comments on Ron‘s videos changed his mind about the utility of videos and I thought the issue was done. But here we are a day later. Ron posts two new videos with multiple variable differences and we are commenting on what we hear from the videos and Ron is confirming that Brad and Bonzo heard what he hears in the room and he is paying attention to what people are commenting on the videos.
Either Ron thinks the videos can be used to promote discussion on how the two videos sound or they cannot. Regardless, the comments seem to be influencing next steps.
Star quad?Temporary RCA interconnects are Gotham from Amazon.com
I have said very consistently that with only one variable, one change, the videos can have some value. Yes, Sherlock, in this particular case there is a second variable -- the presence and absence of the thin acoustic panels. I consider them to be a trivial difference.
In my own experiments I can barely hear the effect of the thin panels on the front wall. It has the effect of taking a little bit of edge off the 4 to 5 kHz range. This leaves, in my view, only one primary variable -- the amps swap.
Yes, from your point of you having the panels is a second variable, which in your view apparently makes me dishonest or disingenuous or something, but I think that in this particular case the second variable is relatively trivial. I respect your view that the second variable of the thin acoustic panels is a monumental and dramatic violation of my own personal "only one variable" videos rule.
Technically, you are correct. I said only one change, and here I am posting videos with two changes. Practically I don't think it matters materially in this particular case. I think the differences in the sounds of the amps overwhelms the presence or absence of the thin absorption panels on the front wall.
Honestly, I forgot that the first video was made without the thin absorption panels, and I recorded the video last night with Jadis without realizing the first "Fields of Gold" video was made without the acoustic panels.
So ankle-biting is okay as long as you're the one doing the biting?
I wonder what Al makes of your confirmation now that others hear from the videos what you hear in room.
Do I need to repeat one more time?
And:
Why are you still stubbornly and consistently misrepresenting both Ron's and my views on videos, Peter, and based on that misrepresentation shouting victory from time to time?
Our position over the years consistently has been that as an absolute measure of sound videos do not work, but that for relative comparisons they can have some (limited) usefulness. It is not that all video per se is useless. What is so hard to understand?
Do you stubbornly continue your misrepresentation either because you simply cannot understand, or because you want to do so on purpose? Either option is not exactly a good look. So please drop it.
Ron clearly repeated yesterday his stance that in terms of absolute measure, to get an impression of the actual sound of the system, videos are misleading ((post #2852, thread page 143):
"As a way to understand the sound of a system in a room in which you have not been present I think videos generate more confusion and heat than understanding and light."
Yet consistent with what he said over the years, today he posted a relative video comparison of two amplifiers from which some usefulness can be gleaned. Again, what is so hard to understand?
My earlier comment today about the bath-tubby nature of the sound of many phone videos, following a comment about Ron's room acoustics perceived to be too reverberant when from in-person experience I know that they are not, was about the aspect of absolute sound through the videos, the representation of which I said to be inadequate. Again, consistent with my position over the years.
I did not comment on the relative amplifier comparison.
It's absolute representation vs relative comparison.
Absolute representation vs relative comparison.
Absolute vs relative.
there is always the possibility that you will withdraw from the record some thing as did Ron yesterday. We all change our minds. You once declared you would not comment on videos. But now you do. That is great and most welcome.
Is this still with KT90s or do you have EL34s in there now? If not, then EL34s will likely push it even further in the warmer/softer direction...particularly something like Mullards.
Peter's report that the videos sound radically different to him is utterly baffling to me.
The difference in the two seems quite significant and I was surprised but possibly reflects how panels can be very revealing of differences in the amps that drive them.Brad and Kedar are reporting correctly what I hear as the differences in the room between the two playbacks:
Brad: "The Jadis is quite a bit softer and warmer sounding." I think it does trade off a bit of resolution for a more "pleasing" listen
Kedar: "The video on top sounds harder, clearer, and I can hear more how she is singing with more fluctuation in the voice.
"The video at the bottom not have the hardness and no stand out thing, balanced, but keeping out info"
I appreciate you posting videos, hope you find a recording method that better represents in-room sound.If we're being technical I should point out other variables:
Single-ended interconnects on the Jadis versus balanced on the VTLs
Radically different woofer level to account for approximately 6dB drop on RCA side
Balanced interconnects are Belden 1192A
again, I think these other variables are trivial compared to the difference in amplifiers.
