When the question turns to hybrid amps . . . my answer is Absolare Hybrid Monos.
Thrax hybrid is very good too
I'm sure! Is that the Koda 160 that Lloyd loves?That Koda hybrid is supposed to be very good...
Weren't the Lamm and the NAT on a different version of the Sigma speakers? I think the one with the high sensitivity paper mids is likely the better sounding speaker, no?It was the least good sounding of 4 amps heard on Sigma MAAT. Kondo was by far the best, then Koda, then NAT Magma. Different room, but the Magma owner also previously had the Lamm hybrid and did not like them. He now has the Aries Ianus hybrid monos and prefers them slightly to the Magma. I haven’t heard the Ianus is person but his videos confirmed it was slightly better than the Magma
No, that is all SS. the K-70 is the hybrid...their first amp.I'm sure! Is that the Koda 160 that Lloyd loves?
Another owner said that the K70 was better than the 160 and he made a mistake to “upgrade “No, that is all SS. the K-70 is the hybrid...their first amp.
I am not surprised the Ianus is better...they are superb sounding amps. I am assuming they were the Essentias?that is only my guess the paper mids is what makes that version better. Either way the NAT was better than the Lamm hybrid on the same version, plus the NAT owner before had the Lamm hybrid in the same room and had the same impressions as I did. He now has Ianus and NAT both and prefers Ianus.
the other thing was with the Lamm hybrid it was pretty hard sounding, like you said, which was otherwise not a concern with this speaker at all in the other three systems.,
I am sure my preference would go that direction. Plus, I thought it was a cool concept to have one power supply chassis and two "monoblocks".Another owner said that the K70 was better than the 160 and he made a mistake to “upgrade “
Speaking with Robert, my takeaway is that the K10 and K70 evolved in his mind in the K15EX and the K160 where being agnostic as to tube or SS, he wanted to really super-drive the performance envelope by creating an extremely low-noise floor, ultra-purist approach to sound. Something which had high signal-to-noise, low distortion (but not thru negative feedback but by obsessive approach to his point to point wiring, his circuitry & topology, his attenuator, his double-walled shielding internally, etc...No, that is all SS. the K-70 is the hybrid...their first amp.
YesI am not surprised the Ianus is better...they are superb sounding amps. I am assuming they were the Essentias?
With AC preamp? Ageto? If not, then missing a lot of the potential...
Pity, not even close to an Impera or Ageto.No Riviera preamp
Congrats...and...how does it sound?Cardas Clear Reflection long single-ended interconnects are installed
Ei KT90s
NOS Mullard 12AX7 long plate square getters
NOS Telefunken 802S
NOS Mullard EL86s
all swapped into JA100s
C'mon, Ron...you're a great writer! how good? how much better? And yes, if I can visit, I definitely will!It sounds good to me!
Come visit!
