Ron, those look like three different types of supports. Could you explain why they’re different and what you are planning to support with them? The set on the left is very similar to the ones in the middle but the left edge is a different angle.
There are only two types of supports: singles and doubles. The single units support one cable, and the double units support two cables arranged in parallel. From the opening of the conduit in my right side wall the interconnects will run parallel until the left channel interconnects goes past the right channel interconnects and continue on by themselves to the left channel.
I don’t know about different angles — it must just be how the photo was taken. Each piece should be symmetrical.
These lifters will be used to support interconnects and speaker cables and power cables.
The burning question remains what happens if you cradle two wires in the single ones!There are only two types of supports: singles and doubles. The single units support one cable, and the double units support two cables arranged in parallel. From the opening of the conduit in my right side wall the interconnects will run parallel until the left channel interconnects run past the right channel interconnects and continue on by themselves to the left channel.
I don’t know about different angles — that must just be how the photo was taken. Each piece should be symmetrical.
david
Thank you Ron. Are the double supports for interconnects running parallel and the single ones for power cords and speaker cables?
it could just be the angle from the photos but the base looks like there’s an angle and the left edge looks like it’s 90° from the top and perpendicular. I was just curious if they were meant to be put against the wall or something with that right angle.
I used special ceramic cable lifters, back when i ran cables on carpet. The extra little loop could be used for for interconnects ! Or just for holding when used for coffee!I originally intended the double supports for Interconnects running parallel, yes. But now I am planning to run two pairs of cables from the line stage, so I will have to figure out how to arrange the cables on the supports. I may just order from Mike a bunch more double units, and use the single units for power cables and speaker cables.
The lifters should be perfectly symmetrical, not straight on one side and sloped on the other.
I see some nice naturally made cable holders on your wall, I can buy into those lifters.I used special ceramic cable lifters, back when i ran cables on carpet. The extra little loop could be used for for interconnects ! Or just for holding when used for coffee!View attachment 102537View attachment 102538
"Number Four" from the left, please turn aroundYes i like all Pink Floyd albums equally !View attachment 102539
