Site Founder, Site Co-Owner, Administrator
Alll of us are hoping you might do the same with your future systemThanks Ron, you had me at you will record your future system
I use a Lutron in my room. There is no audible noise that I have ever heardCongratulations Ron,this is exciting!
For the record I personally never met a dimmer that didn't make noise however I dont remember hearing any from Mike and Steves room so check with them.
The other thing I’ve been discovering is that despite enormous amounts of EMI all over the listening room it’s not clear that these EMI readings have an actual, audible, deleterious effect on the sound coming of our stereos. Everybody who has a PS Audio power generator loves it — despite the fact that the regenerator amplifier itself generates EMI.
I do not use any audio conditioners in my roomRon, Do not ignore or omit the possibility that others tried the PS Audio in their systems and decided to sell it or not buy it. We have read instances of people removing them and preferring the sound without.
Where am I ignoring or omitting that possibility? I’m simply saying that people who love their PS Audio regenerators keep them. Someone who got one, decided he/she didn’t like it, and sold it, no longer has it.Ron, Do not ignore or omit the possibility that others tried the PS Audio in their systems and decided to sell it or not buy it. We have read instances of people removing them and preferring the sound without.
It did not occur to me that you would assume that I would think that every single person who ever buys a PS Audio regenerator loves it and keeps it.
I personally have no plan to get an isolation transformer or a power regenerator or a power conditioner.
I have the same Lutron Maestro dimmers. Even though my light are on their own circuit, I never noticed any RF/DC contamination in my system until my EE friend suggested he build me a DC Blocker for my complete front end.Like everything else, it’s complicated!
It’s great that you don’t have any noise that affects the stereo.
I have discovered that the different models of Lutron dimmers emit radically different levels of EMI. The Lutron Maestro RF dimmers that I have generate a huge amount of RFI — because they literally are RF transmitters.
I always wonder if I played a video of my system and recorded the sound from the Marantz receiver and Radio Shack speaker at my shop would anyone know the difference?Only because people like you find it interesting, and I am happy to cater to my audience.
Yes, I can't explain it to you but I'll ask Phil if he can give me a basic description of how it works.A DC blocker? So it’s a high pass filter which suppresses DC?
(I am confused because typically EMI/RFI noise suppressors are low pass filters which block frequencies above the audible range.)
Yes Ron, I'm already wrong. You are correct in you description.Yes, I can't explain it to you but I'll ask Phil if he can give me a basic description of how it works.
I may be all wrong already.![]()
I would run CAT7 and fiber....My remote control installer person does not want to connect the ethernet cable upstream of the router and switch. He says that would be external to the network’s firewall. He would like everything behind the firewall.
So the ethernet jack for the streamer in the audio equipment room would come directly (or indirectly through a series of ethernet cables and connections) from the router in the garage.
Is there any particular brand and model of in-wall ethernet cable I should specify?
Thank you. I think my distributed remote control system is based on CAT6.I would run CAT7 and fiber....
Hi Ron,
@my home a central router is providing internet to the house, incl my music room. To feed the in wall distribution a simple switch was installed.
I improved the set up in the following way:
- isolating transformer between power wall outlet and power splitter
- better (Keces P8) PSU for the router, feeding the Melco S100 switch as well
- better (buffalo) switch between routet and LAN inwall input for the complete house, but not for the music room
- Melco S100 switch between router and LAN wall input for the music room (the melco changes the in Ethernet prio for Media content
- between Router and Melco S100 and Wall Wireworld Platinum 8 LAN cable
- in the music roon I installed the Innuos switch in front of the musicserver and streamer
(innuos is optimized to provide a „clean“ Ethernt signal
- Wireworld Platinum LAN cables as well
- all digital components in my music room are on a seperate powersplitter, which is connected to a isolating transformer to not disturb my analog set up
I hope, this will provide you some ideas
