Have you done a proper comparison?
I think it's a fair question. Well, at least some kind of a comparison.
Have you compared regular in wall wiring to the JPS Ron mentions? What were the differences?Define proper Keith. There wasn’t anything about sound in my post.
david
Yes, I’ve spent years testing wires, panels and ground configurations, I believe I posted pictures of some of the tests in the forum a while back. For flexibility in the listening room I always run wires over ground from the panel it’s very easy to do additional runs and test them. Pictures of that in @PeterA thread. I didn’t care for the JPS it has a type of coloration that I don’t like, ie not natural sounding. On the other hand off the spool copper wire from the supply house was much more natural. I didn’t find much difference between electrical wires of same spec, of course the grounding schemes played a significant part in overall results.Have you compared regular in wall wiring to the JPS Ron mentions? What were the differences?
it seems hard to do unlike normal cables hence my question.
Yes! Mostly air…I had a strange dream last night. I dreamed that today is the day that I connect an MSB DAC to my line stage preamp with two white, heavy gauge, solid core conductors about two feet long.
To make the connection between the DAC and the preamp with these hard-to-bend conductors I first had to push both of the conductors through a tube of thick marshmallow about a foot long and about three inches in diameter.
Is marshmallow a good dielectric?
I woke up before I learned how this system sounds.![]()
And, which flavorful adult beverage were you sipping last night Ron?I had a strange dream last night. I dreamed that today is the day that I connect an MSB DAC to my line stage preamp with two white, heavy gauge, solid core conductors about two feet long.
Or product were you smoking?And, which flavorful adult beverage were you sipping last night Ron?![]()
Cables I am planning to evaluate:
Mogami or Belden interconnects (whichever brand and model is recommended by David) (these will be used for the 50’ run between line stage pre-amp and bass towers) (...)
