I once tried an 80w Einstein on Analysis Omega. Mahler 2 starts slowly, then takes off. We tried thrice, every time before take off the amp would shut down.
Which Mahler track?
Why don't you try the Danley Soundlabs, it looks like a PA speaker, and you can even hang it in two corners of the ceiling, with a sub down on the floor, and they run it with Crown like high powered amps. It sounds pretty nice, there is music all through the room, a bit like live acoustic music coming through a PA system. If I was not into OCDed audiophilia I would have bought that.
Not answering directly to Exlibris ..'
THe Sh50 or 60 are speakers I would like to listen in a an Audiophile set-up. Our industry being what it is these speakers would be rejected off-hand since they are Pro speakers but from many people whose ears I know and respect, they're the real deal.
I wouldn't use them in tha on the corner in the ceiling, rather would go through the painful process of finding the best on floor placement for these, put them on well engineered stand and use multi-subs for the lows... That is if they float my boat. That they are horns and well designed doesn't mean I would love them...
Which Danley model did you hear? Was it the sound or the look that prevented you from buying it?
Which Mahler track?
(...) THe Sh50 or 60 are speakers I would like to listen in a an Audiophile set-up. (...)
Although I praise audiophile curiosity I would like to ask why? Technically they are 100 db/W, suggesting a good speaker for audiophile SETs, but have very large impedance variations, that would be a mismatch for people concerned with measurements. Using them with most typical high power SS amplifiers would just imply we would be using the amplifier at higher distortion - at low powers distortion usually decreases when power increases.
A good reason why is it's one of the closest approximations to a point source horn, which is (IMO) the definition of ideal for music reproduction. The big deal with Danley Synergy is the way it presents the music. If you haven't heard a good point source horn speaker (most have not) expect to hear the best soundstaging/imaging you've ever experienced, a speaker like this transports you to the venue. The compromises are the midrange ports into the sides of the horn and the overall profile of the horn will cause more diffraction than is ideal and there will be some unevenness in the frequency response. The FR could be tuned to be more even with the crossover but this isn't done because cost and application do not require it (info right from Danley).
Red Spade audio has a version that might be better suited for home applications:
http://www.redspade.com.au/audio/PSE-144.php
However, for home use I believe there is a better, simpler way to accomplish a similar objective, and that's the speaker I'll be releasing soon.It has no ports in the side of the horn, uses a LeCleach profile for less diffraction, and the midrange horn covers from 400 - 15000 Hz, which results in it sounding like a point source even with nearfield listening. Also, frequency response is more even in the critical midrange. It uses a Fostex T500AMkII super tweeter, the mid and tweeter as a unit are about 105 dB efficient and they have only a single cap for xo on the mid and tweeter, so very SET friendly... bass is active with 32/384 DSP and NC500 amps. Downside is it can't achieve the SPLs of a Danley but it can hit 120 dB at the LP as a stereo pair, which is more than enough for anyone and any style of music. I expect this speaker to be better than similar-looking speakers from Avantgarde, Odeon or Cessaro.
Please ship a pair to London, wuth amps and all, happy to review![]()
On the historical website the efficiency of Caliper and Cal Sig is quoted at 84DB. I think that is an error. It even talks about the uplift in efficiency, which I was aware of anyway. .
I was really talking real world load. The video I took shows 93 DB peaks at around 75 Watts for the Duetta, but that is with highly modulated bass, not 1KHz, which is where efficiency calcs are generally done. If you watch that video, it drops to about 3 Watts for a simple guitar strum but subjectively that is still pretty loud. Bass is where the power needs to be to play at volume.
I'm not gonna argue the point. But I do know I tried a 50 Watt PP valve amp and it just died on Duettas - completely unable to play at realistic volume. A Graaf 50/50.
Again, Duetta, Duetta II or Duetta Signature...rather big difference between the first two and the Signature. What do you mean by real world load?? The Duetta has an impedance that varies from about 3.5 ohms to about 5 ohms. Easy load, just put the amp on the 4 ohm tap and you should have pretty efficient power transfer. You realize that bass simply doesn't sound as loud and that 93db at higher frequencies is pretty loud. The Sensitivity (it is not efficiency) of the speaker will be the same in the bass as in the mids if the FR is flat. Sort of how that works... I have no knowledge of the Graaf 50/50 adn what it can or cannot do. Room size, distance from the speaker and the distance of the speaker from the wall behind it are of course very important for an Apogee when talking about sensitivity because nearly half the sound goes backwards and comes back reflected...if your wall is 4 or 5 meters away then you can expect very little to reach you from the reflection. I had mine just over 1 meter from the wall behind and I sat about 3 meters from the speakers.
Mahler 2, first movement, channel classics...
Is that the track you played here that saw the power meters almost at full excursion i.e. nearly half a KW?
My original Duetta Sig refurbs. But the same would happen with my Duetta Interstellas, which are one of a kind. 400-500 e-mails and a lot of telephone conversations developing those, but that is another story
I meant bass load i.e. heavy bass modulation in the source. I thought the next sentence made it pretty obvious. It requires power. The video makes it obvious, though the mic misses the low frequencies should anyone play it back on a high end system.
I am slightly amused, Brad. We have you claiming how little it takes to run an Apogee to good volume, and countless others firmly in the other camp.
All I was saying is the obvious. Think "why do subs use high power class D amps". Reason? To drive large cones to large excursion levels. But if there is little bass in the source material, that power isn't required.
So, with heavy bass reggae, for instance, low power amps will simply cop out at low SPL levels compared to high power amps, which CAN supply the required power. Not rocket science. Without the high LF modulation, the low power amp will do better.
Your argument about the bass drivers is what is amusing. A large driver is often MORE sensitive than a smaller one. Go look at many of the main driver manufacturers and look up and down their bass driver lineup and you will see that for a given design, the larger the driver the more sensitive it is. A large cone also needs less excursion to achieve a given SPL level all things being the same up and down a given design. The impedance is usually quite similar up and down a line as well. The simple truth is that if you want to use a small woofer as a sub you need a lot of power whereas a big woofer will usually require much less. This is why all those Classic designs from the 30s-60s used BIG woofers...15 inches or larger that would make high SPL with low power. Small drivers that need large excursions to make substantial bass needed more power than was easily available at that time. Now, to make a woofer go really deep you have to make the cone very heavy to get the resonance frequency down...but this also affects sensitivity. Even then though, a larger woofer will be more sensitive than a smaller one of the same design.
