Don
Wouldnt you agree that if one can, with eyes closed, localize the postion of a sub in the room it is due to it being crossed over too high thus adding some mid range. IOW IMO a well placed and set up sub should be essentially invisible in the room if crossed over correctly
Yes indeed, with the caveat that "too high" is a variable having different values for different people. Another kicker is that smaller speakers may not have the range to go low enough to get below that threshold of localization, so you end up having to cross over higher than you'd or lose a section of the audio spectrum (or get it highly distorted). Finally, there's that pesky crossover slope to deal with, since brick wall filters are hard to come by, espeically ones that don't absolutely trash the group delay (and thus phase response) for an octave or so above and below the crossover point (digital filters have about solved that problem -- hurray for technology and the engineers that made it!
In my case, I freely admit that my sub placement is driven partially by aesthetics and a gut feel that may not be valid, especially since I am crossing over an octave below what I know to be my personal localization point. However, I have moved the subs around quite a bit (durn heavy things, not good for an old back!), and not found significant differences in measured response, though some locations sounded/felt better or worse to me. I am not sure I could truly localize the sub in any of those cases, though of course if it's very close I could feel the pressure wave and it didn't always seem to line up well with the sound from the mains. Sometimes, it did! Depends how careful I was dialing everything in.
Does that help? - Don
